my new VNL630 SHAKES and JUMPS anbody having this problem
Discussion in 'Volvo Forum' started by 4586man, Oct 22, 2016.
Start with the easiest thing first have you had your steer tires balanced
ExOTR, KB3MMX, Duckman1005 and 3 others Thank this. -
That's not kosher driver.
What Bakerman said, or something simply isn't tightened properly in one of the steering components. You need to go by a dealer and get it figured out though, before something snaps or you do excessive wear to something that shouldn't. -
That's unacceptable. I only needed 5 seconds of that to put that thing OOS. Fix immediately at a proper shop. Whatever the root cause.
Had the same problem recently at certain speeds; (50-55mph & 65-67mph worst) inner steer belt had broken along with loosing some wheel weights.
New steer + balance & alignment = perfection.KB3MMX Thanks this. -
start with Centramatic then had balance my dealer put different wheel & tires on think its all from rear ends win it goes to JUMPING it fulls like you are in a old pickup truck wheel hopping loaded are not
Take it back to dealer and get it fixed.
Before something terrible happens.
IF it is not from the steering axle.
Maybe your rear axles are out of line.
You say it is jumping. I would look at the drive train. Any noises, grinding, metallic grating. Maybe the rears are not in time with each other and one has to spin in place to catch time with the other. This would cause the jumping. Or maybe a rear gear is just binding inside the housing. Axle bearing. I am just guessing. Hard to tell without actually driving the truck.
New truck I would definitely take it back to dealer immediately and get it fixed. This should be covered under your warranty.
Good luck. -
volvo told my dealer they told that its X E package 2.64 gears & computer program. they toke this program still SHAKES. I told them something is not Balance in the rear end. how its #### up more. Mechanic today if they can't pug there computer to it are LOSS. dealer was going to change all 10 tires & wheels from a new volvo mechanic drove it 1st got me I drove it. it shakes more than my it has that X E package. i got the Attorney general in to this to
Force dealer and VOLVO to play with fixing this truck and get another with same spec.
4586man Thanks this. -
Wow that's awful
Is it new new... Like 2017
