My Pre Tripping Method
Discussion in 'Experienced Truckers' Advice' started by fins2feathers, Jan 30, 2012.
  1. fins2feathers
    fins2feathers Bobtail Member
    40
    9
    Jan 27, 2012
    Athens, Alabama.
    Now it's a standard that in almost every truck stop in the country if you look at what does and what does not happen on a normal basis, the least likely event that does not happen, but should happen more often than not is a good pre-trip inspection.
    Now I'm not saying that not everyone does one at one time or another, but almost more often than not, you don't see very many truckers doing a pre trip inspection really at all.
    A lot of the time I run nights. My reasons for doing night runs are simple but very effective strategies. First I like to drive when the scales are more than likely closed, also I might add that theres much less traffic on the road and to top it off you can almost always find a really good parking space during the day rather than looping the parking lot all night waiting for someone to pull out.
    Most of the time when doing my pre-trip inspection, I do it while i'm fueling up at the pump. See I park my truck and do my 10 hr break and save the fuel up for my pre-trip. You really don't get a good oil or fuel level until your engine warms up so why not check it at the pump after you come on duty. Besides they'er both on-duty not driving and in the same place normally where you would park during a break.
    I always clean my mirrors and lenses all the way around, also I give the windshield a good washing, can't see if it aint clean, now is also a good time to toss that stinking garbage out of yur truck along with those nasty piss jugs just sizzling with an odor that says don't remove the cap or I'll stink you out.
    Tire pressure, yah" how many people do you see actually checking that very often, do you even know whether your tires are inflated properly or not. Most likely you don't. And the temperature really can play a trick on you. Cold tires show a lower reading than hot tires and most people don't even got a clue about that idea. I always kick-em and kick hard, just to see if I can feel that tattle tale sign of under-inflation, a sign I might have been dragging a tire I didn't know I was dragging before. Checking your lights at night during a good pre-trip can make the difference on the next driver seeing your rig thru that old thick nasty fog or maybe to some family traveling home on a long trip from a vacation abroad. But that big one that most drivers never check in almost every inspection is the smallest of lights the license plate light, oh" yah" you can get a ticket for not having one operational, but most likely it won't be why they stopped you in the first place. Little things make bigger impacts on not only you as a professional driver but also to those around you. Showing you care about your rigs operational status really shows you are indeed a professional driver.
    Be Safe and Have a Happy Ride, Sincerely DMus
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    You're joking right....
    You should be checking your coolant and oil level BEFORE you start the truck and move it to the pump for fuel. Best time to check levels is when the engine is cold...
    You don't mention checking for leaky hubs/wheel seals so I'll guess that you don't do that either OR again, you do it at the pumps AFTER you have moved the truck and trailer. They 're best checked when they are warm too...right>:biggrin_25523: :biggrin_25523: :biggrin_25523:
    Onetruckpony and DrtyDiesel Thank this.
  4. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    maybe they did a very good post trip?? And to be staying at the fuel island for MORE time than necessary, you are being ignorant. If you did a PROPER pre-trip, you'd be there LONGER than the time it takes to fuel up. Further, how do YOU KNOW many truckers do not do a pre-trip? By your simple deductions from what you DO NOT SEE??
    YES, check the fluid levels when "cold" as every drop has settled. this is a true(er) way to do it.
    I do a pre -trip each night before I start up. When I return, I actually do a post-trip. This is a better time to check the hub seals as well because any oil getting sprayed around will be easily seen on the tires. When I am at the fuel island, I do JUST THAT, FUEL and wash my windshield, the typical fuel island work. I do not play ignorant and needlessly block the fuel island. YOU would be surprised at even the night time driving I DO, there are ALWAYS trucks coming in for fuel, and I am at the fuel island anytime from 12 midnite to 3 AM..!!!
    SO for YOU to do a pre-trip at the fuel island, makes YOU the jackarse we are always biotching about blocking them!!!
  5. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    This is my pre trip.
    Turn on my lights, walk around the truck bumping my tires and looking at my lights to make sure their working. Then I get in my truck, start It up, and let her warn up a little then tug on my trailer and test my trailer brakes. Then I hit the road.
    When I first got my truck I did an hour long look over of it to see if there were any problems. There weren't.
    So, therefore I don't check my brake pads and drums every day, cuz chances are, I didn't run through a set of brake pads in a day. I check my oil and coolant levels when I fuel. I check my oil more often since my truck drinks a gallon a week.
    In school we always did a full inspection, in orientation we always did a full inspection.
    When I got with my trainer he told me you don't need to do that every day if your in the same truck. You know your truck.
    I believe 100% that if you want to do a pre trip every morning that takes up 30 minutes of your time then feel free. But because you don't see other truckers doing them at truck stops doesn't mean they haven't looked at the truck at all. My pre trip takes about 5 minutes, maybe less. I do my post trips off duty since they take less than a few minutes. Post trip I check my lights, tires, and any damage to the truck.
    fins2feathers Thanks this.
  6. fins2feathers
    40
    9
    Jan 27, 2012
    Athens, Alabama.
    Actually you're kidding to what I mentioned, I gave a brief mention to doing the pre trip, I did not specify the whole thing word for word if I had you'd still be reading an hour later, yes I check all my levels before and after I start the truck, All Im suggesting is do some of the pre trip items at the pump to finalize your pre-trip inspection, more over how about this pal. How about actually doing your pre-trip inspection like millions of drivers never do everyday. They get up, write it down and drive off without so much as even getting out of their truck just to look at anything period. Now that the truth has transpired you can't tell me you haven't seen it a thousand times a thousand how many times you actually witnessed trucks pull up to do their break and then they just leave. sure they might get out and take a leak on the side of the truck tire to mark their spot but actually do a pre-trip before they leave, give me a break thats a crock of "bs" and we both know it. Hey if you're going to do anything at all do it where you can see it, at least at the pump you got lighting and other accessories like usually and air hose, water, paper dispenser to check your oil with and a waste-can to throw out your garbage. Besides, did I mention you actually get to fuel up there? Imagine that? the use of pre-trippin at the fuel pump, hey maybe you'd be showing to other drivers you actually care about doing anything at all to your rig not only to keep it safe for your loads but also to the other people that use the highway while you're pulling your load down it, All I'm saying is once in a while try actually doing the work with out just writing it down...
  7. Gizmo_Man
    1,226
    599
    Aug 15, 2011
    Hardly around
    this is true, you DO KNOW your truck, so i do not always "check my brakes" each day either, HOWEVER, as I am post-tripping, I DO CHECK the axle seals/hub seals, as this is when oil spray is more readily seen, and at the same time, since I am looking, I can also see my brakes as well.
    fins2feathers and DrtyDiesel Thank this.
  8. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I do my pre trip at the fuel pump IF i stay at the truck stop where Im told to fuel. This morning all I did was check my tires and lights. I do carry a flashlight so I do have light to see what I need to. I only did a small pre trip this morning because yesterday I fueled up. Put a gallon of oil in my truck, checked all my tires and their pressure, cleaned all my windows and added fluids because I was on my 34 hour reset and that's what I do on my 34's.
    I will agree with you, I still have yet to see anyone get out of their truck and do something as small as a walk around except a few drivers.
    Also I have one of those 50' air hoses that you hook to your emergency air line on the tractor. I use that to air my tires when they need it. I keep them at factory psi. 110 on front, 90 on rears
  9. fins2feathers
    40
    9
    Jan 27, 2012
    Athens, Alabama.
    You guys are worried about someone holding you up at the pump, lousy excuse. You pulled up behind the guy who just happens to be doing something,you got a choice you can back out of it and move to a different pump or watch the guy actually do something, its not like you just watched him grab his shower bag and head in for a rinse, you do have a choice. Now the guy who's gone and you see not a single hose going into the tank, oh ya I got ya", but to actually do something other than pump fuel, now thats ironic" Let me hold you up at the pump, by showing you I care about my rig, let me show you I'm willing to pull up and even be willing to go park just to get something to eat or to take a shower but at the pump, Im on-duty not driving, checkin what needs to be checked before I get down the road and find myself with the triangles out trying to figure out what went wrong, I got a clue... Do you?
  10. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Kicking truck tires is pretty dumb. You can injure your foot for 1 and for 2 you will NEVER know what the actual pressure is in those tires by kicking them (or thumping them with a tire thumper/hammer).
    When I hook up to a new trailer or get assigned a new truck I do a thorough inspection INCLUDING checking the tire pressure with a tire gauge. Of course I carry an air hose with me so i can correct the problem on the spot and dont have to search for a truck stop with an air hose.
    You would be surprised how many times I have found under inflated tires. It is common for me to find tire pressures around 75 psi and under. You won't actually detect low inflated tires until the pressure has dropped to 60 psi or less with a tire thumper. By then you have already damaged the casing and shortened the tires life.
    Be sure if you advocate doing a proper pre trip you do it "correctly" yourself.
  11. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I don't take a long time at the pumps out of respect for other dirivers that are on a tighter schedule than me. Plus when I fuel in the morning its about 3am. Usually the island isn't busy.
