My qualcomm started tripping and lost all my logs
Discussion in 'Questions From New Drivers' started by DAX_, Jan 28, 2018.
  1. DAX_
    DAX_ Medium Load Member
    603
    504
    Sep 4, 2017
    Luckily I had a fresh 70 an only drove from Texas Dallas to Louisiana. But as I was driving the qualcomm screen just went black. Would come on, then go black again. It's actually still doing it as I'm making this thread. I called qualcomm customer service but the automated system said they are closed on weekends and hung up on me even after pressing 0.
    Once I got to Lafayette I noticed that my clock reset again and my qualcomm is on a 60 hours 7 day instead of 70 hours 8 day schedule. Not to mention it shows my mileage today as 98 instead of the 300+ miles I actually drove.
    Help
    Steel Dragon and Lepton1 Thank this.
  3. farmboy73
    farmboy73 Medium Load Member
    549
    681
    Oct 23, 2015
    Knoxville, TN
    You can (should) switch to paper logs until the QC is functioning properly. The regulations allow you to switch to paper logs for up to eight days if your electronic logging device malfunctions. Just log what you actually did and continue on paper in the short term. You are required to keep a paper log book in your truck just in case this occurs.
  4. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    If you drive for a company have them fax you your last 7 days as well.
  5. ethos
    ethos Road Train Member
    4,249
    10,474
    Mar 3, 2013
    Fort Worth
    QC problems happen every once in a while. Just run paper and you will be fine. Call night dispatch, they may be able to send a mobile reset and that might fix the problem. Probably won't though, sounds like a trip to the shop is in your future.
    Steel Dragon and blairandgretchen Thank this.
  6. dptrucker
    dptrucker Road Train Member
    4,695
    3,219
    May 14, 2012
    adelanto,ca.
    Find the black box and unplug it for 15 to 20 minutes then plug it back in.
    Lepton1, Tico79 and Steel Dragon Thank this.
  7. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    Run paper until it gets fixed and you are legal. Right?
    Steel Dragon, Lepton1 and 06driver Thank this.
  8. farmboy73
    549
    681
    Oct 23, 2015
    Knoxville, TN
    Yes. Up to 8 days.
    Steel Dragon and IluvCATS Thank this.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    Correct, but remember the last 7 is still needed. Should be able to be faxed from the office to a ts.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,812
    18,697
    Nov 1, 2010
    Burnsville, MN
    If you have a battery cut off switch, use it.
    Cut the power for 10 minutes, then turn it back on. The computer will then boot clean.
    I have QC problems with my current truck as well, and forcing a cold boot can help things.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Correct. Even if you are on an ELD you must have blank paper logs available in the truck to show a DOT officer on request, this is to show you are ready and able to switch to paper logs in the event your ELD has a catatonic seizure.
    IluvCATS, Dan.S and Steel Dragon Thank this.
