My trucks got a little shimmy
Discussion in 'Ask An Owner Operator' started by Nuge31, Jan 27, 2018.
  1. Nuge31
    Nuge31 Light Load Member
    80
    54
    Sep 7, 2017
    Hey guys, I was pulling through Pa last week (which either means I am going up hill or going down hill) at about 80k. I was coasting down hills pretty good (maybe 75 or so) then would immediately start back up another hill and a couple times when I hit the throttle the truck would vibrate fairly hard,, I would let off the throttle for a second,, then get back in it, and it would be fine.. I am an inexperienced owner and I haven't dealt with a u joint before, but this sure feels like what I think it would if I had a bad u joint.. only happened a couple times, and always coming off a pretty high speed coast to starting to throttle up heading up the next hill.. Any of you guys ever deal with this? Thanks brothers!
  3. 6rider
    6rider Light Load Member
    107
    68
    Oct 24, 2016
    Ontario
    Sometimes things like a height leveling control valve moving can effect the driveline and make it seem like its the u-joint through vibration and rattling. Did you maintain your u-joint, i.e. grease it if it's a greaseable one? Doesn't hurt to look underneath. Your u-joint could be loose from a weared knuckle. There are usually wear tab indicators where the u-joint meets in the knuckles. You could inspect it by looking at uneven wear on the sides. Good luck on whatever is your causing your vibrations!
  4. xsetra
    xsetra Road Train Member
    5,170
    7,105
    Aug 21, 2011
    Easy to check your u-joint.
    Lay under and push up and sideways. If there is play in the joint change it.
