My turbo has started to chuff, how long till?
Discussion in 'Ask An Owner Operator' started by 77fib77, Feb 19, 2016.
  1. 77fib77
    77fib77 Road Train Member
    10,278
    63,760
    Jul 7, 2010
    St Louis
    My lovely isx 870 turbo is blowing a little bit of oil and has Sarted to make a chuff sound part time. How long till it's dead?
  3. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    1 mile or 5000 , its not long for the world , you could do far damage than if it goes kaboom
    ramblingman and 77fib77 Thank this.
  4. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Usually when they go it's rather sudden...You might want to deal with it in a convenient place rather than some out of the way place. A friend of mine just paid a small fortune getting his replaced in a small town because he thought it would last a bit longer.
    Terry270 and 77fib77 Thank this.
  5. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    It def saves you money if you do it soon, and how and where you want. Turbos rarely let loose idling in a parking lot where you can work on them. They usually come apart while your pulling a hill, on a blind corner, with no shoulder, at night, and either raining or snowing. Don't know why but that seems to be the case more times then not.
  6. joe016
    joe016 Light Load Member
    120
    29
    Jan 23, 2016
    Get it done if you are hauling and it goes you may have to have it tow save a lot more money now .
  7. 77fib77
    10,278
    63,760
    Jul 7, 2010
    St Louis
    Well I have a load on and 700 miles Togo. It's only 11000 pounds.
  8. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    Luck of the draw on your run. You're tossing a coin. I'm gonna bet you're gonna complete the run. Would get it fixed right after to prevent tow.
  9. AModelCat
    155,603
    Like was said above, hard to tell how long you'll get but once it goes, its gone.
  10. rollin coal
    rollin coal Road Train Member
    13,133
    26,144
    Mar 29, 2008
    TN
    Doesn't matter if you have a load or not. Mine blew up when my truck was empty and I was turning low rpms (about 1,300) and not really any boosting to speak of.
    If you change it now you will save yourself a few hours extra labor and extra money. If it blows up it will send tiny pieces of aluminum throughout your system.
    The CAC will keep those pieces from going into the engine but you will have to remove it, dump and shake it out, then steam clean it really good to get the oil out of it.
    You will have to tear down all of the rubber elbows, hump boots, etc and thoroughly clean the insides (and outside while you are at it) of those.
    You will have to throw away the air filter. If you try to save money by not throwing away the old air filter you will destroy your new turbo as soon as you crank the motor.
    None of this is difficult but if it blows up you just have a lot more time involved and some extra costs. It's a simple job to swap a turbo you don't have to be a mechanical guru. About a 3 hour job if you take your time.
    I know it sucks being on the road and worried about it. Mine blew up about 40 miles from home. I parked it at a grocery store lot about a half mile from where it happened and did the swap in the parking lot over the course of the next few days. Had to bring everything home to clean it though. If you were just swapping a turbo you could do it anywhere. All you need is a socket set and a big prybar. Inspect all your hump boots and everything while you are at it, replace if needed.
    rank Thanks this.
  11. taxihacker66
    taxihacker66 Road Train Member
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
    Hmm never heard one chuff??
    Had a Detroit that went POP.
    Does someone have a video example of one "chuffing" or able to describe the noise? Is there any visible signs ?
    Thks.
