My Volvo is telling me that the trailer marker light circuit is open...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pmracing, Mar 27, 2013.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    But it tells me even when I am bobtailing!
    I did not see a forum for truck repairs. I hope it is ok to post here. Maybe it could go in the Volvo forum but it may no be just a Volvo specific problem.
    Has anyone had this problem?
    Mikeeee
  3. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    [h=2]My Volvo is telling me that the trailer marker light circuit is open...[/h]
    ...so close it?
    Is your truck trying to nicely tell you your fly is down? I dunno....
  4. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    Mine did that. Turns out one of my blinker lights wasn't working. Don't know if that's your issue or not.
    Pmracing Thanks this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    LED lamps?
  6. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    The Volvo I run would show me that my running lights on the truck had an issue when I first turned the lights on and than the message would go away. It took me a couple of days to catch it and it was the license plate lamp that caused it due to corrosion.
  7. Pmracing
    6,354
    3,178
    Jan 28, 2011
    All the lights on the truck are working. And so far every trailer I have hooked to as well...
    No I have not changed any to LED.
    I will check the rear license plate lamp on the truck. I don't always check it daily since I don't have a rear plate.
    THe confusing part is that it says a "trailer circuit" even when there is no trailer connected.
    Mikeeee
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    check light cord plugs for corrosion ?? unplug from tractor and see if code goes away .my shaker had corrosion on backside and caused similar codes
    vikingswen Thanks this.
  9. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    had the the same thing but with a trailer.. it was a fuse,, its labeled on your fuse panel.. theres a few, 20 amp i beleive.. it's might worth a try
    the plug in for the tractor tail lights is another place to look un plug it clean if needed plug back in, had some bad wiring there.. easy fix
  10. dca
    6,834
    11,427
    May 31, 2011
    Earth
    The fuse replaced on the dash on mine was cased in metal.. can't see inside if its bad, it's the same as the plastic, where you can see if it's burnt, what can cause it is a surge when hooking up pigtail from tractor to trailer with flashers and lights on, good luck!
