My winch bar made a believer out of me.
Discussion in 'Questions From New Drivers' started by Dr. Venture, Jul 19, 2008.
  1. Dr. Venture
    Dr. Venture Medium Load Member
    577
    125
    Jun 29, 2008
    Ithaca, NY
    I don't usually wear a hardhat. Yes, I know what my company's policy is, but bad habits are hard to break. Thankfully my shipper required them.
    I was strapping my load, thought my winch bar was in the hole all the way, and gave it all I had...
    It was pouring rain and I was soaked, the ground was slick with oil, and I was rushing. Everything added up just right and my winch bar owned me today.
    ...The bar twisted, I slipped and on my way down the winch flung my bar out and it smashed me in the side of the head. I got knocked silly for a few seconds, but I didn't get hurt.
    If it hadn't been for my hardhat, I'd probably still be on the ground unconscious. I was in the back of the plant in a lot that was separated by a row of shrubs and trees. The only person I saw was the fork lift driver and only when he came to load me. I'd have been there for awhile.
    I carry one of the big, heavy winch bars with the box on the end that can be also be used to snap binders. The box is what hit me.
    I am now a believer. When that bar comes out, so will my hardhat.
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I have the same kind of bar. When I was in kansas city one time at a J I seen a panhandler approach me. I usually shrug them off, but he had a bar like I had not seen before. It had a paten pending waiting on it as the label said. Good looking bar and he said after the patent comes out he could not sale them anymore. I asked him how much and he said 10 bucks. It has a hook that bites. Sometimes our winches are bent and you can't get the type bar that you are talking about thru both holes. This bar only needs 1 hole to bite. I have slipped several times with the other bar when it would not go all the way thru the 2nd hole.
    I don't use this bar a lot, but it grips really well and you can get better angles of a bite with it. It is a little akward getting the feel of it tho compared to the other type bar. I think all of us have had close calls with winches and bars. I would not recommend getting your finger in the latch either.....:biggrin_2559: Most guys name those latches some awful names....:biggrin_25523:
  4. Dr. Venture
    577
    125
    Jun 29, 2008
    Ithaca, NY
    It's a great bar. My company issues little crappy ones, but for attitude adjustment purposes I decided to upgrade.
  5. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    You need to redo your signature. May I suggest? ......
    Walk soft and carry a big winch bar. Plus don't forget the brain bucket! (hard hat):biggrin_2559:
  6. GuysLady
    GuysLady Trucker Forum STAFF Staff Member
    18,041
    11,881
    Jun 20, 2007
    The eye of the storm....
    The worst I have ever done with a winch bar is drop it on my toe... that was quite enough thank you! I always wear a hard hat and steel toes when I work with them.
  7. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    I had one hit me in the chin once. Threw my over weight butt ### over tea kettle. I was laying on the ground moving my chin around to see if I had a broken jaw. Whew I got lucky, just 4 stitches was the worst damage.
  8. formertaxidriver
    formertaxidriver Heavy Load Member
    767
    375
    Jan 22, 2008
    Aiea, HI
    Had a friend who was flatbedding in Watkins Shepard. While tarping a load had a bungee break and took the hook in the eye. Last I heard he lost his sight in that eye and would need the monocular exemption on his medical. So, safety eye protection while using bungees, I believe they even have that stamped on them...
    Wench bars: get one with the knob on the end or ridges. They actually have square hole wench boxes with a square end bar. Less chance of slippage, but when you work with company equipment, you take what you can get and do the best you can.
