N14 1998 Volvo vibration/shakes
Discussion in 'Ask An Owner Operator' started by Taskpimp, Sep 20, 2024.
  1. Taskpimp
    Taskpimp Bobtail Member
    15
    Feb 26, 2024
    Help Please!!! why is my truck when I am bobtail it does shakes a little bit but when I have an empty trailer or loaded the vibration/shakes is more often and last 1-2 right after putting it in gear. If im driving 65mph in gear and i take my foot off the pedal and accelerate again i can feel the vibration.
  3. DUNE-T
    DUNE-T Road Train Member
    6,943
    16,843
    May 10, 2015
    Detroit, MI
    Can be so many different reasons, but I would start with leveling valve and injectors
    cuzzin it Thanks this.
  4. cuzzin it
    cuzzin it Road Train Member
    3,498
    8,797
    Jan 19, 2008
    Berea, KY
    Then maybe see if driveshaft is out of balance or u joints are bad
    Diesel Dave Thanks this.
  5. Taskpimp
    15
    Feb 26, 2024
    Supposedly is an injector, but i still have a doubt because the truck shakes 3-4 seconds when im going uphill
    77fib77 Thanks this.
  6. MD-n14
    MD-n14 Bobtail Member
    Feb 9, 2023
    Just had that happen to me last week(not for the first time).
    I am not an expert but I would say it sounds like an injector going bad.
    Finding which one it is, that might take a while but hopefully you can get it right.
  7. abyliks
    abyliks Road Train Member
    3,881
    9,074
    May 2, 2010
    ludlow MA
    Shakes is a broad term…
    leveling valve or tire out of round would be a shake
    injector would be a sputter that you would feel in the pedal with smoke out the stacks…
  8. Taskpimp
    15
    Feb 26, 2024
    Same feeling? Have you take it to a shop?
    MD-n14 Thanks this.
  9. Taskpimp
    15
    Feb 26, 2024
    I check the leveling valve still intact. And the tire i took them to balance it a few weeks ago (2 weeks)
  10. Taskpimp
    15
    Feb 26, 2024
    One more thing I dont see any smoke coming put from the exhaust but sometimes I can smell it though
  11. MD-n14
    Feb 9, 2023
    Not sure exactly what was your experience. However, on my truck, cummins n14 engine, whenever I shifted it into another gear, when I press the accelerator pedal, it would feel like it is shaking for about a second or two.
    Right now, I will tell you exactly what was my experience as I don't wan't you to unnecesseraily spend time or money on a part that is good. Ok, so in my experience, an N14 failing injector can have few different symptoms. In my last case(not the first time it had happen), which sounds similar to what you're experiencing right now, whenever I would upshift OR downshift, AFTER I would press the accelerator pedal, the truck will shake for a second or two. To keep it simple, please give us more details as to what exactly happens while driving. I will do my best to help you out.
    - I did eventually take the truck to my mechanic to replace the faulty injector, but that was after I found the failing injector.
