n14 air comp odd issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chainslingr, Apr 1, 2015.
  1. chainslingr
    chainslingr Bobtail Member
    31
    Mar 24, 2015
    Hi all. We've got a 96 379 n14 1.2 m miles in framed about 100k ago. The compressor has been passing oodles of oil for awhile now. Builds air like a lizzard blowing for extra cash. The owner said we had another truck with a n14 and they chased a similar problem for months I guess they had some other problem that would cause a good compressor to blow oil through. Couldn't find anything in any search's anything you guys have ran into?
  3. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    get a new air compressor.
  4. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    a cut or broken line from air compressor to truck dryer will also cause slow air buildup. Also check dryer to wet tank air connectors.
  5. chainslingr
    31
    Mar 24, 2015
    It builds air and holds air with no problem. Is just dumping oil. One of our other wreckers had the same problem and when they changed the compressor it still had the oil blow by problem. No one can remember what it was though. What I'm trying to find out is if there is a common problem with them that can cause oil blow by other than the compressor
  6. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Compressors with a restricted clean air intake, or a restricted oil drain will blow oil.
    Smellfunny and Mr.X Thank this.
  7. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Speaking of oil drains. Don't you just love those guys that use silicone on new compressor mounting gaskets or water pumps. We have a shade tree that works on trucks in our area. Whenever someone comes in and I see that red silicone I always ask the customer "did so and so work on your truck?" And they say "how did you know?"
    Heavyd Thanks this.
  8. chainslingr
    31
    Mar 24, 2015
    Yea we have a few techs that are obsessed with rtv. We also have a few who use heat shrink butt connectors and don't shrink them. Anymore I tend to try to do as much work as possible on my own truck as I cannot stand other peoples quality of work.
  9. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Exactly! Never played with trucks air compressors much, but have painted a lot of cars and seen the same thing happen, just from over-spray plugging a filter.
  10. chainslingr
    31
    Mar 24, 2015
    the intake is fine nice and clear which I would assume would also cause slow air building which Isnt a problem. Mr.x it draws air from the intake manifold as some one decided the easy to change filter on the sidthe the compressor was to hard. #### engineers. Which causes premature falure of the compressor. I'll be convetting it to a old style filter as soon as I can get the parts
    Mr.X Thanks this.
  11. Mr.X
    737
    596
    Oct 31, 2013
    Spokane, WA
    Thank you! Thats interesting. Makes me wonder if a bad seal in the turbo could be pushing a little oil into the intake where the compressor could pick it up? I know it doesn’t take much oil and water in an air tank to make it look like you got a real bad problem.
