Is there anyway to by pass the fuel so it dosnt get so hot? . My fuel tank gets way to hot to even touch with my cummins! I would imagine a cold supply of fuel would equal more hp and milage!
N14 Cummins very hot fuel return!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, Mar 24, 2012.
Thats just the way they are and in the winter you wont have to worry about gelling up.
My 3406b had a fuel heater i bypassed it was heated by the antifreeze. I dno what heats the fuel on this motor
fuel lubricates and cools injectors andinjection pump pump returns 6-8 times the amount of fuek it burns to do that. some of these newer engines might be different but that is diesel 101
I used to have a Western Star with a first generation 500 Hp Detroit (DDEC3) that ran hot. I put a fuel cooler on it and it helped the mileage in summer. Any automotive parts store has fluid coolers with 12V fans that'll work. A good 4WD parts place will have good fluid coolers.
Before you spend the money on it make sure you don't just have a tank heater with a cutoff valve that's hard to locate.. -
Thats exactly what I was thinking. Maybe he has in tank fuel heaters.?dave26027 Thanks this.
Mine is the same way. It gets too hot to touch or lean against and if I drive in the rain there's steam rising off it in the summer time...I've got just a 90 gallon tank. Thought about plumbing in a cooler somewhere with a way to bypass it for the winter.
