N14 jake brake issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MJ1657, Jan 17, 2016.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    '00 KW W900L N14
    Yesterday my jakes started acting up. Let off the throttle and jakes come on as normal. Get back into the throttle and they stay on but act like they are on medium or low not on high where I have them set. They do not shut off with the dash switch when they do this. Only way to get them to shut off is to press the accelerator and increase the rpms. You can hear them gradually taper off when you do this.
    Any ideas?
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Solenoid are sticking.
    Aminaz, wore out and MJ1657 Thank this.
  4. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Usually need replacement or is it something that can work itself out?
  5. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    It's probably a broken Inner Spring, you will need to replace Spring.
    MJ1657 Thanks this.
  6. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Sounds like it's fine to rebuild jakes and replace the solenoids
    MJ1657 Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,472
    6,509
    Aug 26, 2014
    It's not self correcting. Pull the three wires off the jake housing's and connect a hot wire to them one at a time to isolate which valve cover to take off. Watch oil flow change from top of slave piston housing, when wire is removed or hand is taken off center of solenoid. If one stops dumping oil the other is bad. If both keep dumping oil the solenoid is bad. C-brakes used to have a lot of problems with springs breaking and spools sticking in the slave valve housing. Use emery cloth intell spool will slide up and down with a pocket magnet. do the bore also. Hardest part is don't drop stuff in the engine.
    MJ1657 and blairandgretchen Thank this.
  8. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    It's OK to run the truck just leave the jakes off right?
  9. Cory wood
    335
    162
    Nov 7, 2015
    Yes should be fine
    MJ1657 Thanks this.
  10. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Thanks alot guys. I'll get it checked out.
  11. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Just got the truck back. It had a broken spring. They got a Jake kit and fixed it.
    Heavyd Thanks this.
