N14 motor mounts
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by whet1961, Aug 26, 2020.
  1. whet1961
    whet1961 Bobtail Member
    18
    10
    Jul 19, 2016
    I'm replacing the rear motor mounts on my 1998 IH 9400 with an N14 cummins. They each have one bolt running thru the middle that takes a 1 5/16 inch socket. I can't budge these with my 3/4 drive IR impact or my 1 inch drive impact gun. I've heated them with my oxygen acetylene torch until I can see and smell the rubber burning. I've got one of the nuts almost cut off but am concerned with setting myself and truck on fire. It's a two piece mount with a round piece below the perch and the bulk of the mount above it. I knew this would be a nasty job, but have never been this stumped. It's a tight working area and I have covered several hoses snd wires with wet rags and have a fire extinguisher and garden hose ready just in case. Is there a trick that I'm missing or has anyone here done this before and knows a secret about getting these out. Thanks for any info.
    drive-away2020 Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Do you have extensions connected to those air wrenches? That really takes the applied torque away from them. Maybe try long pull handles.
    If you have to use the blue wrench would it possibly be easier to cut the bolts on the out side of the frame rail? Try to stay away from all the air lines and such?
    Dino soar, spsauerland and AModelCat Thank this.
  4. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Wow that sounds like a real tight spot.
    I don't know what you call it but I do think there's some type of flame retardant material that if you wrap all that in it won't allow anything to actually catch on fire. I don't know about the heat getting through but it will stop anything from catching on fire.
    The best advice I can give you and I'm sure you already know this is to really be careful where you point your flame.
    If you can't completely get the nut red hot all the way around at least get one side super cherry red hot and get the other side whatever much of it you can catch. The heat will still transfer to expand the metal so hopefully your big gun could zip it off. I have had some really bad stuff to get apart but if I really got the nut super cherry hot I got it apart.
    I don't like trying to cut nuts out of situations like that because the tight fit makes it so difficult that you may actually damage the motor mount itself.
    If you can get in there well enough to really get that nut hot and you still can't get it out maybe you can spin the bolt from the top?
  5. AModelCat
    164,607
    Nut seized or the bolt is seized in the sleeve?
    If there's air lines and such in the way, honestly I think I'd support the engine/transmission and take the entire mount bracket assembly off. Then you can torch the mount bolts out without fear of melting harnesses and air lines.
  6. whet1961
    18
    10
    Jul 19, 2016
    Thanks for the replies. The motor mount is already broken so I'm not concerned about damaging it, but you're right I don't want too hurt anything else. no airlines or electric wires on the passenger side, but different story on driver's side. Pretty oily under there too. I cleaned that up as much as I could and have a fire extinguisher, garden hose and wet rags and a towel wrapped around vulnerable parts. Almost no room for me under there with all that! HA! Also had to remove exhaust to be able to push the bolt up thru the top of the mount after I get it loose. Don't know why IH designed it like that. Thanks again and I'll let y'all know when I get these things out.
  7. whet1961
    18
    10
    Jul 19, 2016
    AModelCat, I think that's a good suggestion. I've looked at those bolts that hold the entire assembly on. I don't know if I can get to all four of them but I'll look again. It's sooooo tight under there. Of course I'm no pro and only work on my own stuff, but I've done some fairly big jobs and this one is the biggest PIA yet. Thanks again.
  8. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    Can you get a grinder on the nut. I have removed part of a nut to relieve the clamping force and that allowed me to turn the nut off with a socket. I don't know how much room you have.
    Good luck
    AModelCat Thanks this.
  9. AModelCat
    164,607
    A carbide bur might work too. Easier to get in to tight spaces than a grinding disc. My biggest worry would be the bolt being seized in the steel sleeve of the mount vs the nut being seized.
    lester, drive-away2020 and xsetra Thank this.
  10. drive-away2020
    drive-away2020 Light Load Member
    68
    261
    Aug 17, 2020
    As said too, about being careful with the flame, I just went through this with some 1- 1/8 bolts holding my trailer shocks down. I was heating the whole bolt, bracket and everything. This caused the bolt to swell up. Once the bolt was swollen, it would not fit through the yoke price of the bracket. Only options I saw next were to heat the yoke piece and hope it expands or cut through the part of the shock that doesn’t have gas, get the bolt more exposed, and keep cutting. About 5 cuts and a day later I got that one. The nuts were seized unlike ive experienced before. My 1/2 Milwaukee gun with 1100 ft lbs reverse wouldn’t get it. I made all sorts of 4-6 ft breaker bars. Used all sorts of sprays.
    but the heating all of that I did my self a disservice. You probably already know to just heat the seized part only though!
  11. xsetra
    5,196
    7,146
    Aug 21, 2011
    My experience with seized shock bolts. Its quicker just to cut/torch the eyelet in the shock and bolt to remove. New bolts are cheap.
