N14 oil leak lower right side.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, Dec 15, 2012.
  1. JakeBrakeChampion
    JakeBrakeChampion Light Load Member
    55
    19
    Apr 14, 2011
    Pennsylvania
    I have a oil leak on right side of my n14. I originally thought it was from around the filler tube but after installing a new gasket still a leak. It drips all along the right side of the pan front to back but after cleaning up along the pan no obvious signs of a leaking pan gasket. It leaks while runnings but really starts pouring out after shut off. After a hard run when i shut it off theres a giant puddle under the truck. Any ideas im stumped
  3. Yellow Venom
    Yellow Venom Bobtail Member
    25
    Dec 15, 2012
    Edmonton,Alberta
    Sounds like the accessory drive seal.
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    drive seal more than likely
  5. ladywrongway03
    ladywrongway03 Heavy Load Member
    766
    328
    Aug 28, 2008
    trotwood oh
    I had n14 had to replace turbo line twice.It would leave a puddle when I stop.the design of the engine makes the turbo line rub on the inside.I have a detroit 60 series now and My n14 was alot better
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Hard to say with out seeing. It could be a piston cooler/Oiler as well. The only thing you can do is clean it good and run it and watch. Have you seen a decrease in oil pressure?
  7. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    Crankcase vent tube perhaps?
  8. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    I was thinking piston coolers too.
  9. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    piston coolers is my thought to,after replacing 1 at a time last time i was in said replace all of them,fairly inexpensive part,if 1 is doing it the others will break soon,have them all replaced
  10. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Agreed. Change them all.
  11. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    I paid cummins southern plains in Houston,tx it cost me right at $4,000 also did pan gasket so get ready
