N14 problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Crimedogg82, Sep 23, 2020.
  1. Crimedogg82
    Crimedogg82 Bobtail Member
    7
    She doesn’t loose speed she looses power an sound a little rough like the it’s the manifold can any one give me some pointers or a little advice
  3. xsetra
    xsetra Road Train Member
    4,928
    6,588
    Aug 21, 2011
    Check the hoses to your air cooler, they could be loose.
    Fuel filter could be plugging up.
    Air in fuel system
    Injector going bad.
    I don't understand the comments about the manifold.
    Many possibilities.
    Good luck.
  4. 6wheeler
    6wheeler Road Train Member
    2,693
    4,768
    Aug 30, 2009
    Same problem here. C15. Buying a new fuel pump tomorrow. Pressure is down currently by 30 psi running at 50 psi.
  5. Smellfunny
    Smellfunny Road Train Member
    1,400
    943
    Jan 28, 2012
    South Carolina
    If you have a broken head bolt on a N-14 it sounds like an exhaust leak. Usually happens on the back head but one of the bolts close to the middle head on passenger side (or from most I have ran across).
    xsetra Thanks this.
