N14 Rods and Mains
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Starline, Feb 29, 2012.
  1. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    My turn to get some answers....
    OK, I know quite a bit about my engine (N14 525 Canadian built)
    But what I don't know is rod and main life expectancy.
    I know Some will say 1 million miles, others will say 1/2 million, others will say take a oil sample, but I have taken pain-staken steps to keep my running hours low. In other words I have a APU...
    The engine has 840K miles, but 10,000 - 15000 less "Running" hours then your typical engines.... APU instead of idling and turn off the engine when I stop.
    My oil pressure runs around 23 psi at idle to 45 at cruising speed, which is very good for a Cummins. The only incident I had was last Sept when I had a injector crack and had major diesel in the oil. I'd say the engine ran the most 2 hrs and had never more then 2 gals over. The mechanic says things are fine, had synthetic oil in the crankcase when it happen and the engine never stressed or got any kind or codes.
    My over all goal is to get a million. 200k or 300k on the engine before a inframe, but that doesn't include the rods and mains...
    How does one know when to change the Rods & Mains and how much does something like this cost to get a shop to replace ?
    KB3MMX Thanks this.
  3. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    In for answer, 1 red top just crossed 1M and still pull strong. Id like to keepp it that way.
  4. PurplePete
    PurplePete Light Load Member
    131
    24
    Nov 15, 2011
    Tyler, Mn
    That's a good question.
    I was concerned about mine to so when my oil pan seal started leaking I brought it to a Cummins dealer for repair, and had the rods & mains inspection. Mine is at 800k, and they were declared to be AOK.
    Mine idles @ 700 rpm, 18 lbs
    Under load @1500 rpm, 35 lbs
    KB3MMX Thanks this.
  5. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    We usually recommend rod and mains around 750k on an N-14 (at least inspection). If you service your vehicle and take care of it I am sure you can get much more. Usually an N-14 is a 1.5 million motor (if taken care of) so at 750K you are mid point of its life. Why wait until 1.2 when you will have to do it again after another 200-300k miles is why we say around 750k.
    simon999, LWT104 and KB3MMX Thank this.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    have you ever gotten an oil analysis done on the engine?
  7. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    A n14 with 840k is getting up there. I'm sure if they get inspected they will show considerable wear. There is no way to know when to do bearings other than havin a look at them. Freight trucks running over the road last much longer than the local dirt guys.
    Main cap fretting can be an issue on early models. Late 1997 there was a change to main brg bolts & tightening procedure. The fretting is worse on trucks that haul heavy. Any caps that show fretting must be have the clearance checked with plastigage. A cummins shop will know this, a local guy may not.
    Measuring the clearance is a real pain in the butt & adds a bit of time to the job. You can chew up a day doin a beaing roll.
    Im not sure what the parts cost but its safer to change them before they fail.
    You're shooting for big miles but I don't think the bottom end will make it. I would change them out & know that they will last.
    snowman_w900 and KB3MMX Thank this.
  8. scoony64
    scoony64 Bobtail Member
    how long will it take to do a bottom end on a red top cimmins?
  9. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Wish they brother back the N14 ... The last good motor Cummins made!!
    boneebone Thanks this.
  10. Jace379
    Jace379 Light Load Member
    146
    96
    Mar 6, 2017
    I have one with a million 4 on it and still running strong other then there crap injectors. Well I shouldn't say strong she's getting tired but I'll blow it and stick a used one in someday.
  11. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    If oil pressure is good I wouldn't bother with them at this point, especially if you've had this engine since new and don't abuse it. We recommended doing rods and mains on used engines simply because you don't know the history and it was pretty cheap insurance. If I recall Cummins came out with a "stiffener plate" similar to what CAT uses to combat the fretting issue, so when you do decide it's time I would look into adding that if yours doesn't already have it.
    snowman_w900 Thanks this.
