N14 smoke on deceleration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stevekw, Jun 27, 2016.
  1. Stevekw
    Stevekw Bobtail Member
    21
    Feb 26, 2016
    Have a 99 W9, n14. Started having a very slight rough feel/sound week or so ago. Felt like a clogged fuel filter, changed filter same issue. Been getting little worse so taking to shop tmrw. But just today I've noticed when I get on the throttle I get the normal little puff of black smoke, but when I roll out of throttle I get quite a bit of white/grey/blueish smoke . Does this sound like injector? This is my first n14 so not sure what I'm feeling
  3. DUNE-T
    DUNE-T Road Train Member
    6,939
    16,822
    May 10, 2015
    Detroit, MI
    I have a feeling it's injector, $450-500 at any dealer. Don't buy it from private parties, my mechanic told me he witnessed a lot of problems with injectors rebuilt not by Cummins
  4. Stevekw
    21
    Feb 26, 2016
    Yea I'm hoping that's all it is. Going to Kenworth in champaign, il first thing tmrw. They've been pretty good about getting work done pretty quick. Not cheap but what is?
  5. X mech
    X mech Light Load Member
    64
    22
    Nov 14, 2015
    A friend of mine went to Cummins in Milwaukee they replaced injectors when the whole time it was a loose plug on the side of the head for the injectors. Check your air filter. Sounds like you may have an issue with compression usually rings. That is what happened to me with my Detroit piston rings on number 2 cylinder collapsed.
  6. Stevekw
    21
    Feb 26, 2016
    Right on x mech! Shop called me little bit ago. #2 injector plug on side of engine wasn't making connection. They are running the overhead while they have it.
  7. Stevekw
    21
    Feb 26, 2016
    Ok picked truck up yestetday. The minor miss is gone, but it's still smoking like crazy on deceleration. They test drove it bob tailed so it really doesn't do it unless ur under a load. I have no more blow by than normal, and after 600 miles my oil level hasn't dropped noticeably. The exhaust smells like burning oil rather than raw fuel. Any chance there's oil getting past a seal in turbo, letting some seep out thru exhaust when lifting off pedal? It wouldn't take much to look bad, and I would think if I'm losing oil thru rings I'd notice a change in oil level. Any thoughts apprecitaed
  8. AModelCat
    158,408
    Usually when an engine smokes blue on deceleration only its worn out valve guides/valve stem seals. Just look at almost any old Powerjoke Ford when they coast downhill lol.
  9. Stevekw
    21
    Feb 26, 2016
    Yea copy that on the Fords, not a fan. Smoke is prbly more grey/white than blue. Just smells like burnt oil, turbo was replaced bout 200k ago by previous owner. But I know he put the cheapest one he could find on it. Guess I'll find out one way or the other!
  10. Stevekw
    21
    Feb 26, 2016
    Well got home and pulled boots off turbo. The fins on front of the shaft were ate to ####, enough slop in it to let it rub housing. You would think a shop charging $100 an hour would check that given the symptoms I told them. Getting a new turbo at Sxhneid diesel in morning.
    Hammer166 Thanks this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    New turbo.. Whoo hoo. You got it!
    Engines should not smoke until temps reach 10 or colder. That much I remember.
