N14 sudden oil consumption with a topend knock
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by masteron, Oct 2, 2022.
  1. masteron
    masteron Bobtail Member
    30
    13
    Feb 14, 2022
    Hi there, any ideas what might be causing sudden oil consumption on a n14 celect plus…
    Oil pressure at idle 12 psi - running 30-35 psi
    It had some bent rods, changed them, it seemed like the injector was bad , and that was making the tick/ knock on the top end
    now it is starting to consume around a gallon a day
    dont know if it might be the valves or the injector which is bad
  3. 062
    062 Road Train Member
    5,852
    31,733
    Oct 20, 2013
    Bent connecting rods? Did you change the whole cylinder pack or just rod?
  4. masteron
    30
    13
    Feb 14, 2022
    Pushrods .. sorry, 3 bent rods on # 3..
    I am not with the truck right now, operator a few cities away ..
    one mechanic says valves, another injector
    OLDSKOOLERnWV Thanks this.
  5. 062
    5,852
    31,733
    Oct 20, 2013
    I could see a valve not sealing causing oil consumption, but I don’t think a injector would.
    Maybe @OLDSKOOLERnWV @Dino soar have some thoughts. They run older 855’s
  6. masteron
    30
    13
    Feb 14, 2022
  7. W923
    W923 Road Train Member
    1,009
    3,012
    Feb 28, 2022
    Maybe the injector was/is bad and caused the piston top to crack. Been down this trail with two of them. Both were customers of mine so I don’t know a lot about the history but that it was almost 100 percent caused by injector problems.
    The blowby was excessive on both to the point it was actually blowing oil out the blowby tube under heavy load.
    Maybe a turbo problem to. I had a plastic sac get sucked into an air filter once and covered a large portion of it. The turbo was pulling oil past its seal because there was to much restriction. It’s easily seen by removing a boot from the turbo side of the intercooler. Turbo may be fine in this situation.
    I highly doubt it’s valves if it came on fast like you said
  8. Big Road Skateboard
    4,395
    20,919
    May 2, 2021
    A bad injector washing down a cylinder wall is possible, but other signs should be visible now.
    W923 Thanks this.
  9. masteron
    30
    13
    Feb 14, 2022
    Like , what should he look for ..
  10. OLDSKOOLERnWV
    16,598
    246,151
    That oil pressure sounds low…..
    Smoke on initial cold start up?
    noise?
    check the air intake to see if turbo is bypassing?
    any oil in the fuel tanks making the fuel look dark?
    excess oil in the air tanks?
    if the cylinder is scarred bad for any reason you will probably hear a tapping noise towards the top of the engine.
    Oil thinned out front fuel?
    Lot of little things to look at, we can’t see it, but if we could we could possibly give better answers….
    062, AModelCat, Dino soar and 2 others Thank this.
  11. W923
    1,009
    3,012
    Feb 28, 2022
    Most likely will see unburnt fuel running out of the exhaust manifold joints or gaskets at each port. It’s going to be really black and stains everything most people mistake it for oil.
    Might also be able to pick up diesel fuel in the oil on a test. Might have something to do with the lowish oil pressure
