N14 with 3.91 gears, 10 speed. Change to what gear?
Discussion in 'Ask An Owner Operator' started by Asalinas2y, Sep 20, 2023.
  1. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    You can up that to 430hp and get 3.55-3.58, you will be absolutely fine. 1500-1600 RPM at 70mph is good, below 1400 is not.
    Asalinas2y Thanks this.
  3. DUNE-T
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    That is gonna be way more expensive than getting new rear ends. A reman 13 speed is $4000-4500, then you need a $3000 core, cut driveshaft, get new shifter and some other small parts.
  4. SmallPackage
    5,666
    18,105
    Dec 20, 2019
    Marion Texas
    The key is letting the engine “breathe” let it work in a spot were it is not being force fed air and heat. Low manifold pressure is best. Running with the turbo spooled up all day just kills engines. I can cruise 1900 rpm at 65 all day and barely make 10 psi manifold 50 on fuel pressure and 600 degrees on pyro and get job done just fine. Rto 13 speed 4:11 rears. Still have plenty of throttle to get outa the way if needed.
    Dadetrucking305 Thanks this.
  5. abyliks
    abyliks Road Train Member
    3,997
    9,399
    May 2, 2010
    ludlow MA
    I wouldn’t even waste money on a reman, it’s like $800 more to buy a brand new one with no core
    tower should be the same, it was under $1000 excluding the trans to swap the last one we did and we paid someone to do it
  6. DUNE-T
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    Oh wow, where did you see a new one for $5k? All I saw $8k and up for new
  7. abyliks
    3,997
    9,399
    May 2, 2010
    ludlow MA
    $800 more then reman+ core
  8. KrumpledTed
    KrumpledTed Medium Load Member
    485
    1,463
    May 6, 2022
    What CPL is the N14? What size tires are you running? The N14 isn’t one to pull down below 1500 RPM, they need to stay in that 1500-1900 RPM range to live a long, happy life.
  9. AModelCat
    161,302
    IMO if you're replacing the rear end strictly for fuel economy you're wasting your time. 7.3 mpg is very good fuel economy IMO. I doubt the gains you'll see will offset the cost for a very long time.
    Unless you've already got the carrier assembly laying around or you've got a lot of miles on that diff I would just run it as is until its time to replace.
  10. W923
    W923 Road Train Member
    1,387
    4,258
    Feb 28, 2022
    If you’re really getting that mileage I wouldn’t touch a thing. Those Rpm won’t hurt it and as others have mentioned low rpm wears the main bearing caps making the block junk or very expensive to fix at overhaul time
  11. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Leave it be.That fuel mileage is very good especially on a non aero truck.Keeps the rpm’s up and doesn’t lug the engine.
