N3 Detroit series 60 Injectors on DDEC 4
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Detroit series60, Dec 10, 2020.
  1. Detroit series60
    Detroit series60 Bobtail Member
    10
    I plan on using a reman DDEC 5 head I have laying around on my 12.7 DDEC 4. I have figured out evrything except the injectors, how can I go about using the n3 injectors ? Can I just change the connectors on the harness and have it work with the DDEC 4 ecm?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I think I would do the the wiring at the dec5 injector connector using the dec4 wiring harness.
    Detroit series60 Thanks this.
  4. Detroit series60
    10
  5. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I was doing some research to see but it is that time to go fire up the machine. There was someone else who posted something on a similar topic going from ddec 4 to ddec5.( was swapping engines in truck) I hope it works out for you.
  6. Trcknwolf
    Trcknwolf Light Load Member
    57
    27
    Nov 24, 2010
    Bellevue, NE
    The DDEC4 engine is a completely different animal then a DDEC5 engine as is all the wiring, ECM's & the ECM programming. The wriring isn't "conversion" compatible. My suggestion is IF you really want a DDEC4 engine, buy a truck w/a DDEC4 engine h be happy.
    swaan Thanks this.
  7. jamespmack
    215,863
    So take this as vague advise. My experience stops at Ddec4. Ddec5 I have minimal experience. #5 head has one less intake bolt hole. What cam profile works with N3 inj. And #4 ecm. What tone wheel works on #5 cam with #4 ecm. I dont know all these answers. Maybe someone will. But I would be asking them. I'm all for using what you have, thinking outside the box. But I feel your asking for more issues than gain. If your not going racing, ecm, cam, injectors your gonna wanna match.
    Brettj3876 and spsauerland Thank this.
  8. AModelCat
    159,619
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'm willing to bet it would never work. I wouldn't even try it. Everything about a ddec5 is different then a ddec4. It's not even the electronic side of things, but injector hights and injector lobe profiles ect ect . If you want a ddec4 get a ddec4. Frankenstein engines rarely work out.
