Navigo...
Discussion in 'Schneider' started by rickybobby, Jan 3, 2014.
  1. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    On a scale 1 to 10, how would you rate navigo? I would rate it an 8, I have a pc miler , but the navigo seems to be more accurate.
  3. ethos
    ethos Road Train Member
    4,250
    11,397
    Mar 3, 2013
    Fort Worth
    A 3. It doesn't re-calculate quickly and sometimes if you're on a yard somewhere and it doesn't recognize where you're at it won't calculate at all. Plus it tells me to take some funky routes. I rarely if ever use it.
    Dinomite Thanks this.
  4. rickybobby
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    Im sorry to hear that.. It works fine for me. Yes, its a little slow re calculating. I like it because its put you at the entrance. My gps puts me at the main office , which is the front of the building.
  5. P51-D
    P51-D Light Load Member
    72
    20
    Jan 25, 2008
    My truck
    I would say a 4.5. I was on 80 going by Chicago and it was trying to route me off the interstate, go a quarter mile then jump right back on. It also has no setting to avoid routing my hazmat load through a tunnel. I will say I haven't thoroughly went through it to see if there are settings that would help. And I agree, sometimes it will not reroute. I use it to compare with my Atlas and rand McNally gps that I have.
    EggoTrucker Thanks this.
  6. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    I thought you were talking about a trucking company with a similar name?
  7. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
    Exit right on to I94 then exit left onto I80,still laugh my ### off at that one
    mickeyrat and EggoTrucker Thank this.
  8. Donnie1
    Donnie1 Light Load Member
    53
    12
    Nov 28, 2011
    Sedalia, Mo
    That little jag actually helps sometimes to get around the traffic
  9. Donnie1
    53
    12
    Nov 28, 2011
    Sedalia, Mo
    I use it every trip so I don't get out of route. It sucks taking the back roads sometimes but it is what it is. I don't like the way it loses its way every once in a while but it's usually pretty reliable.
    When you have an issue with a route or a road, do you go in and add feedback? I figured that option out the other day. It actually works and your update gets changed in the system.
  10. P51-D
    72
    20
    Jan 25, 2008
    My truck
    I haven't messed with it much but that's not a bad idea.
  11. jakecat22
    jakecat22 Road Train Member
    1,529
    26,294
    Jul 1, 2011
    actually, it does have HAZMAT routes. I haven't done it in a while, but I was walked through how to do it with the HAZMAT team once.
    Something like put in the customer code of where you are going in the location search the /(class of hazmat here) and it should route you with an approved HAZMAT route.
    All in all it is a decent system, I give it an 8, although I rarely follow it.
