Need a eaton fuller transmission shop
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W900.92, Dec 3, 2021.
  1. W900.92
    W900.92 Bobtail Member
    18
    6
    Mar 13, 2021
    Hello guys, i am looking for a eaton fuller transmission shop or any accredible transmission shops out there(USA) that can perform a transmission swap from manual to an auto. Before you give grief about automatics I already heard stories, some bad others good. The decision is due to permanent injury. Thank you all for the help.
  3. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    You are gonna need more than just a transmission shop. What year truck?
  4. W900.92
    18
    6
    Mar 13, 2021
    2004 kw900 with a Cummins IXS cm870
  5. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    You wanting a fully automatic with no clutch or just an auto shift? Did they offer a full auto in 04 yet?
    If you really want to do it first you need to find someone that will sell you an auto trans and give you decent money on your good manual. Inland truck parts is who I would start with there. Then you would need to talk to a KW dealer about the rest. You need ecm reprogramming, wiring harness, and your truck won't be hard wired for the extra plug for that, then you need the paddle shifter and lord know what else. Not going to be cheap or easy.
    Far better off to buy a truck with an automatic.
    I took an autoshift out of my Pete and made it manual. That required removing parts and that's easy. Your project will need to add parts you never had
  6. W900.92
    18
    6
    Mar 13, 2021
    Than you, I am aware of the amount of work and money this will cost, do anyone know of a shop that will take on this kind of job?
    Rideandrepair Thanks this.
  7. DUNE-T
    DUNE-T Road Train Member
    7,021
    17,080
    May 10, 2015
    Detroit, MI
    You also will.need tranny computer, harnesses, programming to make everything work. That's a nightmare of a job, unless you buy a wrecked donor truck to swap everything over
    Rideandrepair and W900.92 Thank this.
  8. Ridgeline
    22,636
    120,669
    yeah the kw dealer should be able to do this, they are the best place to get it done. They can provide the right parts and do the ecm firmware changes without guessing.
    it is going to be costly, may be better to get a truck equipped with one instead.
  9. Goodysnap
    Goodysnap Road Train Member
    3,749
    9,120
    Jul 12, 2017
    I agree. Save yourself headache and nightmares of troubles. Find a truck factory equipped with auto.
    Bean Jr., W900.92 and Rideandrepair Thank this.
