Need a little horsepressure.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kptnt2016, Apr 21, 2020.
  1. kptnt2016
    kptnt2016 Light Load Member
    136
    216
    Sep 22, 2018
    I've got a 1987 Pete 379 id like to add a bit of grunt to. This is effectively our backup rig. I'll put 10,000 moiles max on it annually. This truck only runs the Sacramento -> SF bay area -> Gilroy, Ca. all of 160 mile area and a 100 mile radius. wondering what are the best ways to get a little more power out of this old cummins big cam. We'll use it to pull some 3 axle flat/rgn, and spread axle stepdeck loads from time to time. This rig will never gross over 120,000lb.
    No more than 500hp in mind but more torque would really be great. This is a high geared 13spd. eaton, built pretty heavy weighing over 18,000lb.
    Any suggestions are welcome.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    You need to post engine serial number. CPL # on the engine and fuel pump. Anything you know that has been changed.
    Always check your throttle lever breaks over, fuel pressure under load and the AFC before making changes. It is hard to get more out of a sick sled dog. Just my opinion.
    Then someone may be able to give you some good direction.
  4. kptnt2016
    136
    216
    Sep 22, 2018
  5. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    That looks like a new tag that was never stamped? Look for a tag on top of the fuel pump. The reason I asked for both is that if they match you have a good chance that's what you have. Now you may want an injector number.
    Point being you have no idea what engine you have. We would assume something with high output in a Pete. With a tag like that I would assume it is not factory. It could be a 315. The compression ratio and timing would never allow you to tweek it to 500 HP.
    pushbroom Thanks this.
  6. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    Oh: And it is blue?
    Someone posted some pictures of a Cummins they painted red white and blue. That was cool, different, to each their own.
    Cummings did paint some blue. The one I know of is a small cam made in 1971. Can we get a pic of the cam follower boxes on the left side of the engine?
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    You will NEVER get 500 HP out of anything 87' NEVER.
    If you by some miracle did that block is going to grenade on you, overheat (Wait until you discover how small some cummins cooling really is...) or grind themselves to dust inside or simply burn themselves out.
    And for just that little bitty flat part of cali? Impatient are we?
    Title that to me, I would love to have a older iron to nurse along around here doing this or that several times a year. Not in any particular rush.
  8. kptnt2016
    136
    216
    Sep 22, 2018
    Impatient - Yes indeed :)
    It's definitely for sale. We can only run it 1000 miles a year in ca. Make an offer in my pm I may not refuse.
    Runs like a champ (an old champ
    BoxCarKidd and x1Heavy Thank this.
  9. pushbroom
    pushbroom Road Train Member
    1,782
    7,329
    Sep 1, 2012
    If the engine is original, post the last 6 of the truck and i should be able to get the engine serial number
    baha and Shawn2130 Thank this.
  10. kptnt2016
    136
    216
    Sep 22, 2018
    No its tan... I believe it was just over sprayed near the label.
  11. wore out
    wore out Numbered Classic
    16,780
    205,356
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
