Started off with a little vibration, checked driveshaft play, tire psi, lug nuts, shock leaks, everything was fine and the vibrating stopped. Next day im driving and it starts again, im thinking shocks need to be replaced since its almost been 100k miles and im going home so its all good. 3hrs later... BAM!!! Felt like a bomb went under me, instantly lose power and air is draining quick pull off and i see this beauty. Small last driveshaft & one airbag completely blew off the truck, lines torn and another airbag also caught a beating. And im under a load and waiting to get approved for a rental if it even happens. FML lol
Need a little pick me up? Enjoy my children
Discussion in 'Ask An Owner Operator' started by Boosted_SC300, May 28, 2020.
Lost the drive shaft first Im guessing?
Im guessing yes since the airbag didnt explode and it was ripped off the frame with bolt included
Repair and or pinch off the lines, cage what needs to be caged, put in your front locker and carry on to a shop, driver! That's pretty crappy but it can always be so, soooo much worse.
Tug Toy Thanks this. -
That's gnarly, can you tell where the initial failure point was?
Shawn2130 Thanks this. -
I had a wrecker drive me back up to the stealership for repairs, and OH MY GOD does that name fit them so well! 6.5k for repairs and only half of that is actual repair and parts, the rest is BS fees!
Im guessing the failure was the driveshaft u joints that connect to the 2nd(last drive) axle gave out which then made the DS fly off, hit the airbag and ripping hoses -
The title of this post is why commas are important. Lol
Opendeckin, DUNE-T, Deere hunter and 3 others Thank this. -
Opendeckin and LtlAnonymous Thank this.
Here i am trying to share my children with you guys and you turn me down, no more! Lol jkjk
LtlAnonymous and Deere hunter Thank this. -
Where did you load that salt?
