Need a quick answer
Discussion in 'Questions From New Drivers' started by Boattlebot, Feb 24, 2017.
  1. Boattlebot
    Boattlebot Road Train Member
    1,666
    21,079
    Aug 7, 2016
    Does any on know if the lower portion of the left side cabbnit separates from the top part? If yes will the top stay there on its own? This Is the part I'm talking about
    I'd rather lose that giant hole then the right Sid cabbnit with the two drawers that i use as a dresser.
  3. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    A sawsall will fix it. If you are a company driver they may not appreciate your improvements...
    G13Tomcat Thanks this.
  4. Boattlebot
    1,666
    21,079
    Aug 7, 2016
    I ment actually removing it. Intact just unbolting.... but if the top won't come off the bottom it's not gunna work. The tops my pantry
    Lepton1 Thanks this.
  5. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    When I was a company driver with a setup like that I bought stacking clear plastic bins that fit in the lower opening. That's designed for the refrigerator they didn't give you.
  6. Boattlebot
    1,666
    21,079
    Aug 7, 2016
    4 min delay on a double post? Wow talk about random
  7. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    My wife complains about that. My four minute delay means multiple orgasms.
    Shock Therapy and G13Tomcat Thank this.
  8. Boattlebot
    1,666
    21,079
    Aug 7, 2016
    Didn't really need to know that one..
    I found a screw that leads me to be leave that I can seperatw the top and bottom. But will the top stay up?
    Shock Therapy and Lepton1 Thank this.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,707
    18,492
    Nov 1, 2010
    Burnsville, MN
    Not if the bottom is supporting it.
    But give it a go.
    What could possibly go wrong?
    Nothing, I be leave.
    scottlav46 and Lepton1 Thank this.
  10. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Visions of "delivering" an 11'6" bridge come to mind...
  11. Boattlebot
    1,666
    21,079
    Aug 7, 2016
    If it helps my mini fridge would go there.... hence the want to remove it.
    Lepton1 and scottlav46 Thank this.
