Need advice dealing with peterbilt dealer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pavrom, Sep 21, 2016.
  1. pavrom
    pavrom Road Train Member
    3,196
    7,327
    Apr 29, 2012
    NE illinois
    I had my Alighment done in April at peterbilt dealer , all 3 axles done . Paid 400 .5 month later my brand new Michelin tires on the steer axle gone . I purchased 2 new tires , brought truck back to same dealer to check alignment and he said that my drive axles bushings completely shot and they were pretty bad at the time of alignment in April and they did as good as possible that time but this time he is not doing it at all . I laughed at the guy , he checked notes on the service order and verified no notes verbal or written to the customer about bad bushings . He admitted that I wasted $400 on alignment and offered to do it for free this time but not liable for $1100 Michelin tire that became garbage due to their mistake . Service advisor offered to cut me a deal on new bushings installation after this issue discussed with GM ... I have load booked for Thursday and I guess it has to be cancelled due to this situation . Any thoughts about dealing with it ?!
  3. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Take the free alignment, and discounted bushings, and loss on the tires, and chalk it up as lesson learned.
    You took your truck in for an alignment, and they did one. You didn't ask them to eye-ball anything else that might be wrong and inform you about it---they did the job you asked them to do.
    Normally, a shop will "voluntarily" give out information on other worn parts or possible future problems in hopes of getting the extra work (and money)...but they are not REQUIRED to.
    daf105paccar Thanks this.
  4. 201
    201 Road Train Member
    12,634
    25,950
    Apr 16, 2014
    high plains colorado
    I love Peterbilt's, but the worst part of a Peterbilt, is dealing with Peterbilt. I'd NEVER take my truck to a Peterbilt dealer. There's nothing a competent repair shop can't do that a Pete dealer does. If fact, sometimes more. I agree with White Dog, you have to be your own watch dog, although, I'll admit, bad bushings are hard to spot, but if you don't say anything, a dealer won't check, where a smaller shop will, and refuse to align it if there are worn parts. Good luck, and as they say, "That's Truckin".
    Cottonmouth85 Thanks this.
  5. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Hate to say it, you'll have to eat this one.
    Mack dealer in Richmond, VA did the same to me.
  6. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Should they have told you about the bad bushings? Absolutely. Not only did they not give you vital info about your truck but they lost the opportunity to sell a job that legitimately needed to be done. That being said, you gotta catch that kinda stuff man.... The bigger the shop, the more times something has to be communicated over and over again internally before it gets to you. It's like a game of telephone and your at the very end.
  7. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    That's why Dealerships are called Stealer-ships, because they steal your money.
    I'm not trying to be the Devil's Advocate, but in the 5 months since you had your Alignment done you've had to notice that you had a issue by looking at your tires, irregular tire wear doesn't just happen overnight.
    You're not just going to be driving for 5 months and then one day look at your tires and say "Oh crap they're toast.
    I would think you would've been monitoring the condition of your tires during your Pre and Post Trip Inspections.
    Did you also install new front Shocks when you installed your first sacrificial set of Michelin tires?
    When you own your own equipment you can't be complacent, you need to be on top of things and constantly be looking at everything on your equipment everyday, at the beginning and end of your workday.
    A Owner can't be cheap and keep on putting repairs off until your truck breaks down on the side of the road.
    You can't be Penny-wise and Dollar Foolish, you can either Pay Now or Pay More later.
    Cottonmouth85, AModelCat and 201 Thank this.
  8. pavrom
    3,196
    7,327
    Apr 29, 2012
    NE illinois
    Tires don't wear out overnight .... I started noticing this probably after 3 months ... Little by little till they gone . I was not sure what's the problem - completely lost on that one . Previously alignment been done on the truck by different shop and they did only steer axle because it's car hauler and they can't do it due to the low 5th wheel ... Drive axles should be fine - that's what they told me .... After steer axle tires were gone , truck was brought to the dealer and they said one of the drive axles was off 1.5 inches and this caused steer tires to wear out ..... Nothing mentioned about bushings . Normally none of the shops would not even touch the work until all suspension components are in good condition . After I left the dealer in April I was sure my suspension is perfect and all my tire problems resolved now .... Apparently not :(
  9. TruckDrivingtn
    TruckDrivingtn Light Load Member
    246
    236
    Sep 8, 2016
    Maryville Tn
    This is BS.... I have worked in many service dept... If a customer comes in and asks for an alignment the tech better make sure it can be done IE a shake down..... The fact that they offered to handle things makes it even worse... Any shop worth there salt should have done this. The fact that the advisor told him about it based on what the tech remembers makes me believe the tech or The advisor dropped the ball.
    To the OP good luck but I wouldn't trust them to check my air pressure....
  10. AModelCat
    161,581
    If a tire is wearing odd, one would think you would feel the truck pulling to one side.
    I think they did a half ### alignment job the first time and are trying to cover it up now (I always mark down stuff like other worn out/broken parts on my W/O's to cover my ### later in situations like this and to try and upsell legitimate repairs).
    TruckDrivingtn Thanks this.
  11. pavrom
    3,196
    7,327
    Apr 29, 2012
    NE illinois
    It's not necessary to pull the truck due to the odd tire wear .
