Need advice for switching a engine in 07 Freightliner Columbia
Discussion in 'Ask An Owner Operator' started by BHANRI88, Oct 6, 2015.
  1. BHANRI88
    BHANRI88 Bobtail Member
    6
    May 6, 2013
    I purchased a used 2007 Freightliner Columbia with Mercedes Mbe 4000 engine.The dealer sold it saying same as detroit engine.It has over ten thousand dollars in repairs as of yet.It has a blown head gasket now.The mechanics are asking 4800 more .I was hoping to switch engine to detriot S60.Dont want to buy a new one with DPF crap.Has anybody done it before. Please Help .what are goods and bad for doing it.Thank you
  3. rollin coal
    rollin coal Road Train Member
    13,440
    27,392
    Mar 29, 2008
    TN
    Probably be cheaper to fix what you have or sell it and buy a Freightliner that had a factory installed Detroit. You probably don't want to hear this but quit using the half ### cut rate $50 an hour shops and take that truck to a Detroit house. Not a truck dealer. A Detroit diesel shop and pay the $100+ an hour for a proper diagnosis and repair. They will get it right, it will save you money, and best of all they will stand behind the work. I would bet $100 you're getting milked and scammed by some half assed or rip off shop advertising a cheap rate.
    BoxCarKidd and BHANRI88 Thank this.
  4. BHANRI88
    6
    May 6, 2013
    Thanks for the concern rollin call .Detroit dealer has a estimate exceeding 7000.I thought maybe getting a detriot s60 around 8000 and do the swap .Sounds like a good idea.Hoping to find someone here who has done this.
  5. rollin coal
    13,440
    27,392
    Mar 29, 2008
    TN
    Ask in the garage section. It'll cost you more than the trouble it's worth to change out engine makes. I feel your pain. Been there, wrote the checks, and got the t-shirt.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    Just thanking coal for trying to save you money. I never did the swap you are talking about but there are always problems. If that cost you three weeks down time what is that worth? Then you may have an electronic nightmare that haunts and costs you. It could be different if it was a side deal but not for your soul source of income.
    BHANRI88 Thanks this.
  7. AModelCat
    161,297
    Its definitely not worth it. Maybe back in the 70's-80's when engines were mechanical it was easy enough to do. Now its a matter of rewiring the whole truck and a number of other things. If you ever have an electrical issue on the new engine it will be a nightmare to diagnose because that truck will be one of a kind and no one will have schematics readily available for it.
  8. BHANRI88
    6
    May 6, 2013
    Thank you guys for your good insight. Have researched a lot by now. I am not willing to take the risk either.its probably better to scrap the truck. Thank you
  9. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Believe it or Not the dealer Lied to you...
    That Motor is/was Built in Brazil primarily as a Bus engine. They were fitted to Freightliners & Sterling fro a few years due to some loophole/crack in the emission Laws at that Time.
    Subsequently they are Poorly supported by the Dealer network.
    If you have any paperwork regarding the (Alledged ) $10k in repairs, take It back to whomever did the Work & see if They're prepared to stand behind their Workmanship ...
    Otherwise you really only have 2 choices here.
    1) Fix It, then Drive It into the ground & throw It away.
    2) throw It away now.
    Not tyring to be a Smart #ss, just realistic..
  10. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    Your self esteem has been eroded; the MBE is a good motor. Reinvest in the MBE & you'll be the happiest. Myself, I operate a 2006 MBE w/+million miles. Keep the faith
    (MBE is built by Detroit...look over the MFG web site @ Detroit Motors, all publications are available to download)
  11. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    I think that it is his wallet that has been eroded. They put these motors in the Western Star also and they would ge run over by their shadow.
