Need advice on rearends
Discussion in 'Peterbilt Forum' started by Bulldawg81, Apr 9, 2016.
  1. Bulldawg81
    Bulldawg81 Bobtail Member
    Have a 1995 379 Pete with a detroit 60 500 horse with a 13 sp eaton fuller truck has 390 gears but tor the driveshaft out n it screwed up the rear differential I have two options at my disposal a set of 411's or 355's with my 390 I am good on flat ground at 70 I am taching bout 1600 when it starts pulling a hill it loosing alot like I said just need g opions from other owner ops
  3. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    355 is ok, 411s will eat your fuel.
    Eaton has a gear and road speed calculator on their site.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,506
    9,790
    Mar 30, 2014
    Yeah if you're bumping 1600 with 3.90s, you'll be about 1700 with 4.11s
  5. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Got to know your sweet spot of motor. Lugging will burn fuel-over revving with extra power uses fuel.
  6. prerunner404
    prerunner404 Medium Load Member
    452
    223
    Aug 3, 2011
    lake havasu city az
    I have the same truck but 3.70s lp 22.5 rubber and a 10 speed. With this current set up im running around 1600 at 70mph. My truck was speced for tall 24.5's so i actually have to drive 5mph faster to do the speed i want. With that being said if i had tall rubber on 24.5's and my 3.70 rears at 70 mph id be running around 1450-1500 rpm and for my truck thats right where she is happy at and where the motor really likes to start pulling.
  7. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    Bite the bullet and get an 18-speed and keep 355 gears
  8. savage02
    savage02 Light Load Member
    163
    50
    Dec 21, 2007
    Upstate, NY
    Going from a 13spd to an 18spd will do nothing for him. I run that engine myself and from my experience I'd go with the 4.11's in your case. You'll only be 50rpm higher in your gears. It will be a total dog with the 3.55's unless you swap down to low pro tires. I run 295/75/22.5 with a 13spd and 3.58's and its around 1550rpm@70mph.
