Need advise. Another winter driving question.
Discussion in 'Experienced Truckers' Advice' started by Colorato, Jan 15, 2012.
  1. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    When driving in ice/snow is it better to be in a lower gear to keep the RPM's up so you can throttle out of a slide or to be in a higher gear with lower RPMs'.
    Example:10 speed truck. Road is snow covered and you can only do 45 mph. Would it be better to be in 9th at 1400 rpm or 10th at 1000.
    Thanks.
    :biggrin_25515:
  3. volvodriver01
    volvodriver01 Road Train Member
    I am probably wrong, but I would rather be in 10th at 1000 rpms to keep my drives from spinning to fast. I am comfortable with my reasoning though so someone more expierenced will be along shortly.
    Colorato Thanks this.
  4. Colorato
    1,336
    865
    Feb 22, 2011
    Well that's why I wanted to ask. If your to high a RPM your more likely to have wheel spin but to low and it bogs the truck down and it seems like I'm less in control if and when it does spin.
  5. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,300
    Nov 8, 2009
    The Highway To Hell.
    It depends on the situation. Are you going uphill? Down? Flat? Two lane 4 lane? Are you wearing red underwear with blue socks at the time? Lol. Really it depends on the situation. I'd run it in 9th depending on how the truck was set up. 10th at 45 you're just lugging the engine.
  6. Truck609
    Truck609 Light Load Member
    238
    197
    Dec 17, 2011
    Arizona
    Find a good middle ground that you are comfortable with in your current conditions. Snow is much different than ice for example. Too high of rpms, no good......too low could get you in trouble as well.
  7. Colorato
    1,336
    865
    Feb 22, 2011
    Flat road, 2 lane, polka dot under wear. Oh sorry TMI.
  8. joseph1135
    11,340
    27,300
    Nov 8, 2009
    In that case definitely 9th gear. Goes well with. Polka dot undies, lol.
  9. Colorato
    1,336
    865
    Feb 22, 2011
    Yeah it defiantly seems to be a case by case bases. Biggest area I've had problems is with a 2 lane state rd I run every night that drifts badly.
    Thanks again for the input.
  10. Colorato
    1,336
    865
    Feb 22, 2011
    :biggrin_2559:
  11. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I always keep the RPM's low and keep the truck at a nice, steady even pace. The brakes arent your friends unless its your trolley for the trailer. Most people's first reaction in a situation (when its slick) is to slam the brakes. Its very hard to train yourself to NOT DO THIS but letting off the throttle easy or if needed pushing in the clutch are better alternatives. I found it better if the trailer wants to try and slide around ya to floor the throttle and grab the trolley which tries to slow down the trailer and speed the truck up in order to straighten it back up.
    Colorato and hup Thank this.
