Need backhaul information
Discussion in 'Questions To Truckers From The General Public' started by lhare, Jan 18, 2012.
  1. lhare
    lhare Bobtail Member
    4
    wichita falls texas
    This might not be the right forum but figured it is a good place to start. The Bowman Volunteer Fire Department in Wichita Falls Texas is trying to buy a used fire truck in New York. We have had quotes from major shippers and they range from 4500.00 to 8000.00 to haul the truck. How do we find an independent trucker or a smaller company that could backhaul the truck and would have more reasonable rates? The sites that I found online are geared toward truckers and we are unable to fill in some of the required fields. Since none of us know anything about shipping trucks, 4500.00 might be about right. Any help would be greatly appreciated. Thanks Lonnie
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    How big of a fire truck? Most I have ever seen hauled are overweight, which requires permits.
  4. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    You need to get more info before you talk to any company about the rate. Width and Height, and Weight are important numbers. Map the miles also, it's question one to a driver, right before bottom line. My son has looked into moving a couple of different cars from online sellers and it usually hasn't been do-able.
    Over 102" wide is oversize. Height is manageable with a stepdeck or drop trailer but over 10' you can expect the rate to go up.
  5. lhare
    4
    wichita falls texas
    The truck is 30' long, 8' 1/2" wide and 9' 1/2". Weighs 34,000 pounds. Distance is about 1600 miles.
  6. Truck609
    Truck609 Light Load Member
    238
    197
    Dec 17, 2011
    Arizona
    I think someone is dreaming at $8K, but $4500 sounds about right if its a legal load.
  7. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Probably the biggest hurdle will be loading and unloading. Is there a dock @ both ends? If not you will require an RGN and they cost more.
  8. passingthru69
    So you want somebody to haul it for free?
    There is No such thing as a backhaul.
    Glad you got the fire truck to help out the area.
    Just remember you get it hauled cheap it might not be in good shape when and if you get it..
  9. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Try uship. Do yourself a favor, stop using the word backhaul. Makes you sound cheap, and many of the smaller trucking companies consider it a dirty word...
    We gotta eat too.
  10. lhare
    4
    wichita falls texas
    Like I said, we are not truckers and dont mind paying a reasonable rate. At the same time we dont want to pay too much. There is a dock at both ends so that wont be a problem.
  11. mgfg
    1,753
    626
    Mar 29, 2010
    You have just made the job easier and much more cost effective for yourselves then.
    A firetruck with those dimensions is a walk in the park. When you do find a truck, please ensure that it has sufficient cargo insurance to cover the value of your shipment. A simple fax copy and a call to the insurance company to verify coverage will suffice.
    Good luck to you and congratulations to you and your dept on your purchase.
