Need bigger fuel tans!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by J8STARR, Jul 29, 2014.
  1. J8STARR
    J8STARR Bobtail Member
    17
    I have a 2001 freightliner Classic. It has 100 gallon tanks. I want to change to 150 gallons. Getting extensions welded are costing too much. I was wondering if I find used tanks do they have to be from another classic or a freightliner or would any tanks from any truck fit?
    Thanks!
  3. flood
    flood Road Train Member
    4,168
    4,045
    Dec 25, 2010
    for the most part yes they need to be freightliner tanks..... the tanks need to be the same diameter (so you can use the same mounts) fuel cap and gauge must also be in the same spot...... you will need to add a new mount as well unless you have 3 per tank now and they need to be rated for the bigger tanks weight... your old 100 tanks full are about 850 lb. each your new 150 gl. tank full are about 1,275 lb. each
    can you add 750 plus lb. and not be over on your drive's or steers.....?
  4. J8STARR
    17
    um I haven't ever scaled... We have overweight permits. I haul containers from toronto to jersey ports. But I'm assuming I've seen other trucks with the 150 gallon tanks and be good?
  5. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Any good shop should be able to do this. Check Craigslist and ebay for any tanks in your area and then get them installed
  6. bergy
    bergy Road Train Member
    1,189
    1,311
    Nov 1, 2013
    Just wondering, why do guys want 150 gallon tanks? Is it just to avoid filling each day? Just asking because there is so much focus on being as light as possible. Thanks.
  7. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    logbooks. must match fuel to logbooks, less fueling, more room in coloring book.
    bergy and Big_D409 Thank this.
  8. flood
    4,168
    4,045
    Dec 25, 2010
    for me bigger tanks = more money..... I can get more fuel at a cheaper price so I don't need to get 50-75gl. (at a higher price) to get to the cheaper fuel
    icsheeple Thanks this.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really u can fit two ore one additional 100 gal tank...
    the biggest I saw was 150 gal, but 125 gal are available on JYs too.
    25(2)+2 Thanks this.
  10. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Are your tanks under the doors with steps mounted over them? Got pics?
  11. flood
    4,168
    4,045
    Dec 25, 2010
    if the tanks are under the doors you will need to check you steer weight.... adding bigger tanks MAY put your steers over....
    the bigger tanks and 50gl. more fuel will add about 400 lb. to the steers, but 50gl. of extra fuel will get you a extra 300+ miles between fuel stops
    my tanks are all the way to the rear
