Headed into Canada with a couple of loads. Anybody use a smartphone app for an e-log? What e-log works best in Canada? I really want to avoid trouble.
Need Canada e-log advice
Discussion in 'Questions From New Drivers' started by backliz, Apr 28, 2013.
Log in Canada as you do the US and you will be okay.
The program uses the gps function of the phone. This is something that the phone company told me leads to additional charges in Canada, so I disable it. -
First trips into Canada ? A couple of things you need to be aware of . They require a 36 hour restart and the logs from the past 14 days . This is because they require an off duty period of at least 24 hours every 14 days . They also require the license plate numbers of the truck and trailer to be on the log . My e-logs have an option to enter the license plate numbers during the pretrip .
Canada scales really check e-logs thoroughly . It took them an hour to do a level 2 on me at the Trafalgar Scales on the 401 .
We use Xata Turnpike e-logs paired to a Blackberry . Canadian scales have the Xata site downloaded . -
Should have mentioned that I have an Iphone. Xata isnt compatible. Figures. Checking with Verizon to see if there will be a charge. (Thanks!)
Since we are just a small ag business that rarely strays far from the States, we just use a log book. I understand that's due to change here, eventually? Anybody recommend an installed e-log over an app.? -
My phone carrier is Verizon if that helps. -
1) You must have a continuous period of 24hours offduty/sleeper at least once in the last 14 days
2) You must keep logs for 14 days
3) You can only drive 13 hours total in a midnight to midnight time period (possible under US rules to drive 14 if you stop only for a 10)
4) If you are exceeding 70 hours in 8 days & relying on resets, your reset must be 36 hours
5) Your logs must show the license plate numbers of all the equipment you pull (in US you can use truck/trailer number assigned by company)Last edited: Apr 28, 2013
GR8, Rocks and Mark Kling Thank this. -
