Need Cat Acert life span input?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by duramaxnb, Feb 9, 2013.
  1. duramaxnb
    duramaxnb Bobtail Member
    38
    Feb 3, 2012
    Climax Saskatchewan
    I have an 07 freightliner classic with a C15 Acert, this is the first acert I have owned but not my first cat. It has just over 20000hrs on the ECM I just had a top end set done on it and I am curious what to expect or see when I comes to getting more hrs out of this engine. On my last oil change it never used a drop of oil and barely turned dark in 350hrs. The service manger told me the acerts are supposed to keep the oil clean and this one definitely is. What should I be looking for and how long does anyone think these engines can go before an inframe? Thank
  3. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    You guys up in Canada go by Hours and we go by miles. One thing for sure, be prepared to have $20,000 minimum for that inframe!
  4. Real Deal
    Real Deal Medium Load Member
    468
    230
    May 29, 2012
    Saint George UT
    I got 1.2 million out of my Acert before I needed to rebuild.
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    If you're not burning oil, it's probably been rebuilt and updated with new pistons/rings.
  6. 5EE
    5EE Bobtail Member
    16
    Nov 18, 2012
    Winnipeg, MB
    1.1 million miles and counting. Have only replaced injectors
  7. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Mine just turned 20,000 hours this week.
    Doesnt use a drop of oil and its never been opened up.
  8. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Last company I drove for had all Accerts. They were all team trucks, and quite a few had over 1.5 million miles without major work. Fuel mileage was all over the place from one truck to the other, but they mostly all ran about the same.
    Keep an eye on the oil pressure, and if there is a decent jump in pressure when you let off the fuel around 1500 or more rpm, then I would have the main and rod bearings changed.
  9. duramaxnb
    38
    Feb 3, 2012
    Climax Saskatchewan
    Ya up here some go by hours and some don't. I haul oil so I have lots of idle time loading and unloading so going by miles would never work cause it always varies and there is times when it's -45 Celsius and the truck stays running. I have 537000 miles on this unit and it hasn't used any oil and it stays clean but I'm told the acerts are supposed to be that way. Thanks for the pointers just looking for info on what to watch for that may give me signs of an upcoming failure.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    Acert's don't typically use much oil, they blow it all out the breather hose and make a mess out of the front of the tanks. Mine made it to 1,001,600 before I had it inframed. It had started taking/blowing oil at the rate of two gallons a week, and then filled the cooling system with diesel fuel. Have no clue what the hours were on it.
