Need fast answers for brake job
Discussion in 'Ask An Owner Operator' started by supergreatguy, Dec 17, 2020.
  1. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Inner axle passenger side brake caught fire yesterday. All my brake components are pretty old, but I have been on top of adjustments etc. My question is about S-Cams.
    I’m replacing 6x
    - Brake shoes
    - Drums
    - Chambers
    - Slacks
    - and wheel bearing (in & out) and seals on axle that caught fire.
    should I go ahead and swap all cams?
    What oil do I need to use for wheel hub/& diff?
    Should I do all bearings/seals or just the one?
    reason for fire: spring off adjuster? apparently didn’t release brakes on that single side and caught
  3. abyliks
    abyliks Road Train Member
    3,928
    9,212
    May 2, 2010
    ludlow MA
    What year is the truck and are they original? S cam and bushing kit was like $100 per spot I think when I did mine, if it’s an older truck and you plan on keeping it I would just go ahead and replace it all so you know what you have.
    make sure you use both seals go in to the diff, that way the grease pops by the slack instead of into the s cam and getting all over the drum, and use stemco or other quality wheel seals so you don’t have to do them again, and to take up any slack you may have on the spindle
    I just did synthetic 75-90-140 or whatever Eaton recommended for the diffs, each one should be about a 5 gallon bucket or so, was like just over $200 per iirc
  4. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    2006 century. Are you talking about wheel seals?Is there one or two (in and out?)
    thanks for the oil info
  5. abyliks
    3,928
    9,212
    May 2, 2010
    ludlow MA
    No the grease seals on the s cam that get installed in the tube going to the slack, there are 2 bushings in the tube as well.
    you have the wheel seal on the inside of the hub then the axle gasket/silicone you can use on the outside
  6. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    okay, you’re talking about the bearing kit. I bought six cams and six kits yesterday. Is the bearing kit fairly straight forward to swap?
  7. abyliks
    3,928
    9,212
    May 2, 2010
    ludlow MA
    not hard, just time consuming, clean the grease out and punch everything out, use a slightly smaller socket then the tube and lightly tap it in evenly
    supergreatguy Thanks this.
  8. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    okay. White lithium grease on slacks? Or normal red tack?
  9. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Everyone is looking to sue for the easy, big money. Brakes aren't the place to be cheaping out. Brake parts aren't that expensive, replace everything. To much liability nowadays. :occasion5:
    InTooDeep Thanks this.
  10. supergreatguy
    1,030
    2,895
    Nov 26, 2020
    thats what I’m doing, just wanted to know others opinions. I’m at 3.2k for ALL brake components
    black_dog106 Thanks this.
  11. abyliks
    3,928
    9,212
    May 2, 2010
    ludlow MA
    I just use the regular red chassis grease, do it once a month but I don’t drive a lot
