Hello,
First off Im new and driven only a few months. I dont want to break my friends truck he wants me to drive. Heres my problem.
Im familiar with the flatlands but in the mountains pulling hills-Not so much. Winding 6% kind of hills. He wants me to drive this for 2 months and Im freaking out. Here is what the truck has;
13 sp transm/ 3406 Cat. Im confused as to when the splitter comes into play at what rpm and ? Im lost.
I shift at 1600 /2100. Do you always shift 6 OD, then 7 OD etc ? I guess I dont understand how the OD works w the motor.
Any and all help is greatly appreciated. He threw me in and said I know you can do it....Yikes!!
Need help, before I break somethin'!!
Discussion in 'Questions From New Drivers' started by girlygurl, Aug 24, 2010.
Page 1 of 5
I take it you you can shift smoothly from low to high range and visa-versa....
The key is to preselect the next gear or split before shifting or splitting....
So....
6th Drive.....Preselect to OD then let off the throttle.....you now should be in 6th OD...
Then preselect drive....throttle off.....move the stick into neutral......then ease back to 7th drive and ease in the throttle at the same time...Rinse repeat.....
Do you know how to "Progressive shift" btw?
And why do you shift at 2100?....There's no need to bump the governor....even on a kitty....girlygurl Thanks this. -
Unless you are driving a Cat engine that is older than 15 years or so, you can lug them down to around 1200 before you have to shift, and I would upshift way sooner than 2100!
The over drive is like a half gear shift 300 or so rpm instead of around 600. So when downshifting from 12th which would be direct, to 11th which would be an overdrive or the high side of the splitter, you would have to rev the engine 300 rpm to downshift.girlygurl Thanks this. -
I shift at 2000 on flat , 2100 hills. No, to the progressive shifting. Never heard of it- I was thrown in and thats why I have this concern. I feel when Im in the hills I just dont have the horsepower and that Im doing something wrong.
Thanks hardlyevr, but It lugs at 15....? this truck doesnt seem to get out of its own way...
You are shifting way too high....That's unnecessary wear and you are wasting fuel....
What are you getting MPG wise...about 2 MPG?girlygurl Thanks this. -
ok but when Im loaded it seems to "bogg down" if I shift under 15... 5 mpg
and AMEN to the vacation idea..... -
It shouldn't bog down or lug as it were.....
The power-band on that engine should be about 1200-1500 IIRC.....
I suppose you don't know where "peak torque" is on that kitty right?
Look on the data plate on the valve cover......girlygurl Thanks this. -
I guess I dont....So Ive been shifting it wrong...Great!!
Sometimes...Watch what I can do...probably means you shouldnt...!!! -
So with this Cat motor I should shift at...?
Page 1 of 5
