Need help Cummins 855 big cam injection pump sticking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tarvarre, Oct 28, 2024.
  1. tarvarre
    tarvarre Bobtail Member
    21
    6
    Dec 4, 2022
    At first it would only stick when I let the cab up then let it down( idle high) I would have to manually move the rod to idle it down i'm not sure it could be gunk up. I'm thinking of just taking it off and rebuilding it, but I was wondering if there was something simple I could do before I proceeded with rebuilding it, any advice would be helpful thank you in advance
  3. SmallPackage
    5,358
    16,844
    Dec 20, 2019
    Marion Texas
    Sounds like the throttle rod or pedal is hanging up. The throttle shaft on the pump will not return to idle on its own without a return spring with or without linkage. Remove linkage from the shaft arm and leave return spring on. See if it acts normal. If it does then you need to work on the linkage and/or the pedal to free it up. Check the bell crank pivot point on the cab those things get worn and the bushings get wallered out and sticky.
  4. tarvarre
    21
    6
    Dec 4, 2022
    Thanks very much I will look into that thanks once again for your help.
    SmallPackage Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,428
    6,460
    Aug 26, 2014
    Some cab overs had a issue with the linkage. Had to watch how it was working as the cab came down. Flip part of the linkage when the cab was about half way down. If not they would start at full throttle.
    Does it low idle with the cab up?
    tarvarre and Diesel Dave Thank this.
  6. MAMservices
    MAMservices Medium Load Member
    467
    3,193
    Aug 9, 2021
    Just FYI if ya aren’t aware. NEVER lower a cab over down with engine running!
  7. tarvarre
    21
    6
    Dec 4, 2022
  8. tarvarre
    21
    6
    Dec 4, 2022
    Thank you for that bit of information. I did not know that, but I have never ran the truck with the engine running and the cab up
  9. tarvarre
    21
    6
    Dec 4, 2022
  10. tarvarre
    21
    6
    Dec 4, 2022
    I haven't had the cab all the way up with the truck running maybe a quarter up with the truck running but the problem usually is when the truck's not running and I have to re-crank the truck is when the the truck idles high
  11. Diesel Dave
    8,612
    24,181
    Jan 20, 2010
    Hesperia, Ca.
    Boy……. Does this thread bring back memories with my COE K100. :rolleyes:
