Ok guys here is the story. I purchased a Peterbilt about a month ago. Last week few codes pops up for fuel pressure and truck started to loose power, I stopped by Peterbilt dealership in Idaho and they told me there is some issues with fuel pump and it will take about 4 or 5 days to fix it because that was a Friday and they were closed on weekends, so I decided to go back to Chicago and take care of it while I will be at home. On my way truck started to loose power really bad and I towed it to Peterbilt in Dickinson ND and told them that there is probably fuel pump failed (codes for fuel pump were active), they checked a truck and found that turbo was bad, they replaced a turbo, erased all codes and told me that truck is fine and I'm good to go (cummins paid for that by the warranty) 300 miles after I left their shop engine failed, I towed it to another peterbilt in Alexandria MN, they checked it and told me that fuel pump is failed and pieces of metal from that went to the engine and killed the engine and now I need a new engine (which cost 40k $) and Cummins won't pay for that since fuel pump not covered by the warranty and engine failed because of the fuel pump. How is that possible peterbilt's cummins certified mechanic just checked it a day before that and told me that everything is fine and all codes for fuel pump were because of turbo?? How to make them pay for that? Should I hire a lawyer or try to contact cummins first? I don't have any money to pay for that, and dealer just checked it right before the engine failed. Please give me advise what should I do now. Thank you
Need help Cummins ISX
Discussion in 'Trucks [ Eighteen Wheelers ]' started by maxya1986, Nov 2, 2015.
Page 1 of 5
That's a 2012 Pete with 370000 miles by the way
You can maybe offer to split it or spend lots of money fighting over it. Warranties are worthless most of the time. If I have to pay you to stand behind what you maintain is a good product, what is the point?
CM2250? Did you have the fuel pump campaign done? Those pumps were failing and destroying engines. The campaign was a new plunger and a relief valve. The first thing I'd do is contact Cummins and see if that campaign is still open on your engine. If it is, both dealers should have seen it and told you about it. If it's closed, find out what dealer closed the campaign, so if they find that it wasn't done, you have someone to point the finger at.
jsnell Thanks this. -
Idaho dealer informed you of the problem, you decided to push to Chicago instead of get the pump fixed. I wish you luck on getting Cummins to even spit the bill with you. You left after they diagnosed a failing pump, and in that action negated their liability for the problem.
jsnell Thanks this.
Enlighten me on how a failing fuel pump destroys a whole engine.
I just don't see it.
Destroy a set of injectors yes, but a whole engine, how's that possible,?drdesl Thanks this. -
Page 1 of 5
