Need help figuring out a mess with tune/turbo/injectors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sodapop, Oct 13, 2023.
  1. Sodapop
    Sodapop Light Load Member
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    I have a 2004 C15 mbn Cat....600/2050 tune,8502/1100 trim codes injectors and 80/145 turbo.
    thing is blows alot smoke when shifting or if i mash the pedal to go up hill or the pass another truck. Run pretty much flat ground..pyro will run about 900 deg F with 78k load...I run 80 miles then DH back.mileage running about 5.8 where others with same running closer to 6.8.. with no smoke, just Haze...trying to figure what i need to do to get it all lined up closer to right..Any feed back appreciative
  3. HEZ1980
    HEZ1980 Bobtail Member
    6
    4
    Oct 12, 2023
    I'm having the same issues on the same motor. I have no idea what mine is set at though. I bought it this way
  4. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    Is that a Custom tune or is it the Cat factory 600/2050 File ?
  5. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    Put the right trim codes on the injectors would be a start
