2010 Pete 389 VIN; AD795703
Tech striped out bracket that holds ac lines onto expansion valve.
Can someone please help me find a part number, Its not listed on exploded view, and no pete dealer can find it.
Need help finding ac line bracket
Discussion in 'Peterbilt Forum' started by tjlynch20002000, Jun 2, 2014.
Here you go:
5S011895 - Clamp (the part you need)
5S014009 - Socket Head Cap Screws (the 2 screws that screw through the valve into that clamp)
Just in case, while I was in there:
F426061 - #10 O-ring
F426060 - #8 O-ring
3S011516 - Expansion Valve
If your local dealer wants to verify, the section I found it in is:
HVAC Cab Unit & Controls
Cab HVAC Assembly - S31-6038tjlynch20002000 and EverLuc Thank this. -
I give you props.. dealer still has not found this.. but I will get this asap.. thanks a billion!!!
I don't know why, those parts are all on the same screen as the expansion valve. Some things are tricky to find on ECAT, but that was simple. Maybe I should be a parts guy instead of a mechanic
tjlynch20002000 Thanks this. -
if you ever find you self in need of a job and in Stephenville tx.. Im sure I could get you one
Is this for the sleeper cab too?
I looked up cab, you didn't specify. On the sleeper, they sell the evap core and expansion valve as a unit, but there is a note that says for service, use:
5S014332 (this is the bunk expansion valve)
5S013317 (I don't know what that is, possibly the seal)
5S011895 (Same part # as the cab clamp)
5S014009 (Same part # as the cab screws)
So I'd guess that the clamps are the same, but don't hold me to that. It seems that they want you to buy a whole new evaperator core.
I think I'd just give it a spot of alminum weld, then drill and tap it to the right size.
