Need help identifying a Cat 3406
Discussion in 'Trucks [ Eighteen Wheelers ]' started by zx150, May 1, 2012.
  1. zx150
    zx150 Medium Load Member
    343
    45
    Mar 30, 2012
    Getting ready to start an in frame on my '94 KW W900, before I start ordering parts I need to figure out exactly what I have for an engine. The truck has what I believe to be a 3406B and the dealer tells me that the truck originally left the factory with a 3406C. There's no ID tags on the motor that's in there now unless you guys know of a good spot to check where it might be stamped into the block.
    Here's a few photos of the engine:
    So, do I have a 3406B or 3406C?
    Thanks!
    TGUNKEL Thanks this.
  3. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    It's most likely a C. The block number is stamped on the turbo side, you should be able to look thru the cutout in the insulation to find it. It is the blacked out area that you can see on the turbo side picture. It should be a 3ZJ prefix.
  4. cowcatcher
    cowcatcher Light Load Member
    I agree with SmokinCat. You got yourself a 3406c prefix 3ZJ.
  5. zx150
    343
    45
    Mar 30, 2012
    I'm guessing that you're referring to the square towards the rear of the block to the left of the dipstick and underneath the turbo, correct? Will take a look in the morning. Also the serial number I've been given from KW is 4ck16893, will that number be what I'm looking for or is there another number with the 3ZJ prefix?
    Many thanks!
  6. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    If that's the number KW gave you it would prolly be right. The 4ck was a what they call a PEEC engine yours would have originally had an electronic governor on the back of the pump as well as a electronically controlled timing advance and a ECM. It looks as though someone has converted it to full mechanical. It is a good setup now.
    Semi Crazy Thanks this.
  7. dirthaller
    dirthaller Road Train Member
    1,116
    13,001
    Sep 22, 2011
    Coloratah
    I think that cone shaped cover on the driver side near the air compressor means it's a C
  8. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Pretty sure its a 3406b. I thought all 3406c were pec motors peck have elec throttle and the front cover has a couple wires running out of the timing advance cover
  9. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    The most common serial prefixes for the PEEC are 8TC which is a B and and 4CK for the C.
    The thing is since someone has done a conversion on the OP's engine it could be a B pump and advance. The best thing that could ever be done to a PEEC is a conversion to manual, then it is a great engine.
    There are plenty of full mechanical 3406 C's built by CAT, the serial prefixes are 3ZJ, 5KJ, and 8PN. The 3ZJ can be either a B or C depending on when it was built.
    Robert cab over and truckmechanic Thank this.
  10. zx150
    343
    45
    Mar 30, 2012
    Cleaned up that spot on the turbo side of the block the best that I could and couldn't see anything at all, going to try and take a rubbing of it later to see if maybe there's a number there that I can't see.
    Did find some other numbers scattered around the motor, maybe you guys can make sense of these.
    On or near the fuel pump:
    7W3906
    7W5785
    7W688
    7W4886
    SLDC
    On the cylinder head or Jake assembly:
    7E0329
    018402
    On the rear of the motor over the bellhousing on the driver side:
    105100
    Maybe these number don't have any meaning at all but thanks again for the help!
  11. truckerjc
    truckerjc Bobtail Member
    41
    7
    Oct 13, 2011
    hoxie,kansas
    A B has 6 point head bolts & a C has 12 point.
    H2oburymatt and puncher Thank this.
