need help on a well built 3406B
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jlcamp710, Jul 17, 2009.
  1. jlcamp710
    jlcamp710 Bobtail Member
    21
    Clarkville, AR
    want to build up an old 3406b to about 600 hp. is this possible? looking to put it in an old cabover pete.
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    that's nothing. you can get that by doing very little. turn the pump up and put bigger injectors in it. that will get ya close
  4. jlcamp710
    21
    Clarkville, AR
    thanks, medicineman. I didn't know it'd be that easy. So pretty much just have the injector pump worked on and bigger injectors will do the trick? Would I need to go with a better turbo or will the stock factory turbo do the job?
  5. jlcamp710
    21
    Clarkville, AR
    Oh, and just so you know about the 600 hp limit. I spoke with Detroit radiator and was told that they could build up a special radiator to support about 600 hp. Limited space in a cabover.
  6. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    A 5 core radiator will handle 600hp easily.:yes2557:
    Is this an air-to-air motor? If so it will be easy to get 600hp or close to it without buying anything.
    Do you have general knowledge of this motor already?
  7. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    Back to the days of putting the rack screws in your pocket.To many factors when looking for this much h/p from a 4mg motor that was 425 h/p. Larger radiator,air to air a must to make this kind of power! transmission, driveline and clutch to handle more power. A good pyro gauge too for starters plus deep pockets to do it right.
  8. Les2
    5,150
    2,288
    Jul 25, 2008
    You have a good point, but 600hp isn't alot to ask out of a B model. You don't have to change anything other than timing and fuel settings to acheive that. You just have to use common sense when driving it, thats all. You don't even have to take the screws out....yet.
  9. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
    do they handle the power as good as the e models and 6nz
  10. Les2
    5,150
    2,288
    Jul 25, 2008
    The C models on up have the bigger rod bearings so they would most likely hold up better, but if all your wanting is 600hp the B will do just fine. You can go with more HP but you'll have to change the bearings more often.
  11. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    C's are much stronger than B's. I've seen plenty of C's putting out 750 plus HP. C's are air to air. I have a friend in FL who replaced his 3406C with an E and he's selling the C model engine. If you want contact info I'll give it to you.
