Need help on airing off corrosives
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Fast04gt, Jul 29, 2016.
  1. Fast04gt
    Fast04gt Light Load Member
    70
    12
    Mar 15, 2014
    I leased on with a different tanker company that made me put a compressor on my truck for airing off chemical. The shop installed the pto, driveshaft, and compressor but no fittings on the air hose coming from the compressor. i bought a Chicago fitting that will fit it but do I need a regulator? And how big of an airhose do I need for offloading? Could someone walk me through the steps of airing off? I've pulled tanker for a year but used a company installed liquid pump, never a air compressor so I'm new with the compressor offloading
  3. speedyrob
    speedyrob Bobtail Member
    33
    7
    May 6, 2015
    Olive Branch, MS
    :happy1: I would be interested in this as well since I may soon be learning this....
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look at conn. on trailer for ideas reg.3/8 air line can be used or 3/4 or 1in. are most used but all depends on CFM of compressor?
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    When we use our truck air to unload tankers we just run 3/4in hose and no regulator but then again we are using the engine compressor that airs up the brakes so it hardly builds over 12 psi in the trailer before its empty.
    Now if we are using customer supplied air they have regulators set for around 40psi and usually end up having to kinda watch things as we get towards the end as it will get around 20-25 psi in the tank. If it starts creapin much over 25 I will close off the air supply 1/2 way to slow the air flow going into the tank letting the pressure drop. This is also how you should set up your truck. Hard pipe from the compressor to a regulator to a ball valve to the Chicago fitting. Should be 3/4 or 1 inch plumbing and regulator with 3/4 inch hose. The smaller regulators used for home garages are normally 3/8" and will really slow things down flow wise. You would still get plenty of pressure but pressure wont unload the product if you dont have the volume to keep up with the 2 or 3" product plumbing.
  6. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    DO NOT install a regulator on your compressor unless it goes into a tank then you could put a regulator on the tank outflow. Failing to do this could cause , safties to blow on your compressor, something blowing (like, air fittings, pipes, or compressor).
  7. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    You need to be trained....ask.
  8. wis bang
    wis bang Road Train Member
    3,430
    4,066
    Jan 12, 2011
    Levittown, PA
    Training...disconnecting a hose under air pressure can kill you...you need to be trained for your own good.
    you want the most airflow, if the compressor exit is 1", you need to use components that are one inch.
    Same with the air hose, we had one 1/2" and it really made the unload take longer than the 3/4" we usually had.
    You need to understand how to not trap pressure in a hose and understand that even a small pressure differential exerts a bunch of force on dome lids and hose connections.
    Get training. Did I mention that you need training?
    Crude Truckin', bigguns, JPenn and 3 others Thank this.
  9. HauntedSchizo19
    HauntedSchizo19 Medium Load Member
    481
    148
    Dec 19, 2013
    Southern Tier, New York
    Yeah, you need more training. I know it's late...but if you have any other questions, PM me.
    Best of luck!
  10. RogerThat72
    RogerThat72 Road Train Member
    1,787
    995
    Jan 30, 2014
    I think you need to mind your own business!
  11. Bill51
    Bill51 Road Train Member
    1,184
    2,982
    Jul 27, 2015
    Cruise control is your friend. Just keep hitting accel until the engine finally starts ramping up. Think I set it about 1000 rpm. Gets you to 25-30psi easy.
