Need help on turbo oil feed- 3406C
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FreightyAK, Mar 18, 2023.
  1. FreightyAK
    FreightyAK Light Load Member
    51
    42
    Aug 7, 2018
    AK
    As I am going through my project truck I found that I needed to replace the turbo on my 8PN 3406C. I hung an aftermarket E model 177148 on there and my oil feed hard line is too long. I having a lot of trouble finding a solution as the "hybrid" lines that Cat offers is for their industrial C's. The fittings are ORFS and my truck has JIC. Also 90's vs straight fittings. The E-model oil feed connects to the block and the line is much shorter. Mine connects to the oil filter base and needs to be longer. I am looking for the most cost effective way of doing this because so far any possible solution is far more costly than I want to pursue. I'm already 4k over budget. Has anybody encountered this before or have any ideas?
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    just use a hydraulic line
    Bean Jr. and AModelCat Thank this.
  4. AModelCat
    161,703
    Can't replace the fittings from JIC to ORFS?
  5. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    The problem is the end that bolts to the turbo. It's a funky one off triangular block thing
  6. AModelCat
    161,703
    Post some pictures of everything.
    Oxbow and Bean Jr. Thank this.
  7. 062
    062 Road Train Member
    6,292
    33,842
    Oct 20, 2013
  8. wore out
    wore out Numbered Classic
    16,780
    205,353
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have always used the supply line off a 5EK E model. Somewhere I have a part number may take a day or 2 to find we’re out trucking at the moment
  9. wore out
    16,780
    205,353
    Jun 5, 2013
    You can put a pipe plug in oil filter base and come out of the main galley of the block like the E
    Oxbow, FreightyAK, AModelCat and 2 others Thank this.
  10. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    I will when I get back to the shop Monday.
    Oxbow Thanks this.
  11. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    Well, I got it figured out. After some looking around I found an adapter that goes from JIC to ORFS to fit the industrial C oil feed line. The oil line is a hybrid. The angle is slightly different than the one that came off but the flow should be the same. I have everything back together, and all I have left under the hood is the oil change, replace 2 coolant hoses and fill the cooling system. I will be turning the key today then on to the rear of the truck.
