need help setting a rate?
Discussion in 'Freight Broker Forum' started by Largecar359, Dec 8, 2012.
  1. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I have some dry van freight leaving eastern Tennessee delivering 122 miles north to crokett Va. off I-81. I just need some help rating out a local run like this. I was thinking $625 that leaves me some room to make $145 on the run and still give the driver a decent rate. load is 45ft of space weight is 12,000 Ibs. so its light stuff and can fit on a 48 or 53ft. trailer. Is this good or am I too high on the rate?
  3. BoyWander
    BoyWander Road Train Member
    1,411
    2,125
    Jul 22, 2011
    One pick up, one delivery, quick load, quick unload, those are factors too...with short runs, I think time is more a factor than would otherwise be, right, although I'm not an O/O I guess I would ask for $500 if it is quick on and off, and that will leave time for another run that day, otherwise $500 is not enough to gross for one day's worth of work.
    dannythetrucker Thanks this.
  4. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    Typical O/O expects to make a minimum of $500-550 a day. If they don't make ATLEAST that, they aren't making money. Quote it $550 min + fuel at $1/mile
  5. rollin coal
    rollin coal Road Train Member
    13,280
    26,787
    Mar 29, 2008
    TN
    Post it at $400 and make them negotiate. Maybe you get it covered every time with dependable service for that. Maybe there are other options there and it costs money. I wouldn't give away money if I had worked to secure the business. Make every buck you can. I know an o/o locally who has a 50 mile load he brokers out for $275-$300 he gets it direct for $675. It's every Tuesday morning run straight thru no more than 3 hours in the load. I'd do it for $400 everytime but he gets it done for less, who can blame him? If that freight is quick and easy on both ends you should make a lot of money off that load.
