Need help starting my 1989 Peterbilt
Discussion in 'Peterbilt Forum' started by rbanuelos, Jan 21, 2014.
  1. rbanuelos
    rbanuelos Bobtail Member
    8
    Jan 21, 2014
    I have a 1989 Peterbilt, 379, with a NTC444 Cumming's engine. There are times where I am able to turn on/off the truck all day long, then there are times where I turn the key and it will not start. Can you please advise me how to start the truck from the starter, with the key on. And also where is the relay, are those the square fuses in the fuse box where one must be connected to the starter?
    PLEASE HELP!!!!!
    Thank you!
    baha Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    1st CK. all wires from BATT. to starter,then just cross the small wires at sol. to big hot wire. get a person to strike the starter with a winch bar as you push button, if it starts replace starter.
    rbanuelos Thanks this.
  4. rbanuelos
    8
    Jan 21, 2014
    Can it be done by myself with the key on and I hit the small wire to the hot wire?
  5. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Check the ground cable from starter to frame.... Clean it up real good
  6. rbanuelos
    8
    Jan 21, 2014
    I'll check that tomorrow, when I hit the button and get nothing can I jump start it from the starter?
  7. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Forgot to ask if you hear a click as the starter butt. is pushed?
  8. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    It should be the ground cable or a second solenoid on the firewall????? Follow the wires off of the starter solenoid back up to the firewall..... Looks like the old ford solenoids that were on the inside fender wall.... It was the ground wire when it happened to me...
  9. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    If you cant jump it at starter than it is definitely a ground wire
  10. fld
    fld Medium Load Member
    383
    258
    Nov 24, 2012
    Yes, you can jump it yourself (just make sure the truck is in neutral, brakes applied).
    If you have the ford type looking solenoid, you should be able to jump it there. If you have no problem starting it from there, check your switch.
  11. rbanuelos
    8
    Jan 21, 2014
    Thanks once again. I hope I get through the day today.. But no, I don't hear no click when it acts up.
