Need help with 2017 freightliner cascadia? temp sensor?
Discussion in 'Experienced Truckers' Advice' started by AlmostSuperman, Mar 5, 2017.
  1. AlmostSuperman
    AlmostSuperman Light Load Member
    Ive got the idle shutdown on my truck and its temp controlled. Has to be over 70 or under 20 to allow idling. Im looking for the temp sensor for it but because its so new no one knows and i dont either anyone know by chance.
    sidenote: none of the normal idle overrides work cruise, brake realising nothing works
  3. bzinger
    bzinger Road Train Member
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Temp sensor on my 16 is a little stud under the driver side mirror housing ,got an app so never messed with it .
  4. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Apu ..#### spell check
  5. AlmostSuperman
    aww never thought too look on mirror i wish i had apu lol
    Aradrox Thanks this.
  6. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Saw a guy on another post said he tapes a handwarmer to the stud and problem solved .
  7. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Unplugging them won't keep it running if that is what your trying to do. An appropriate ohm resistor can fool it into thinking it is hot outside or as I use to do handwarmers a sock to insulate and a plastic bag taped over the mirror to keep the cooler air out. Could also get a 12v defroster and set that up on it
    bzinger Thanks this.
  8. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Bingo lol
  9. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
  10. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    That sensor is pretty is pretty sensitive tho as I held my fingers on it and the dash temp gauge immediately starting going up .
  11. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    On past year model freightliner cascadia (maybe 2014?) , I was told once it's near the right frame rail up towards the very front of the truck below the radiator. I think the outside temp sensor you read on the dash, and the temp sensor used to control idle and other engine functions are two separate sensors. But I may be wrong. I'm just a truck driver after all.
