I will be on holiday for 3 weeks and my truck wouldn't be in use , Should I disconnect my truck battery? Please help , 06 freightliner
Need Help with battery question.
Discussion in 'Ask An Owner Operator' started by suubiye, Feb 20, 2015.
if your truck is APU euquipped id just leave it. if not i prob would
I guess it depends on what is running off batteries while truck is off. I would prob just disconnect the main pos cable from the 1st battery.
Best to break the main ground.
... Philipflood Thanks this. -
Can someone explain why to disconnect? I leave my truck parked for 3, 4 or 5 weeks at a time and never disconnect the batteries. It always starts right up.
Jerry12 Thanks this. -
... Philip -
No APU on my truck, thanks dammut
All my trucks have always had 4 batteries. I never disconnected battery cable. Just made sure everything was turned off. I have had a truck sit for 6 months and start fine in the summer. Not sure it would have started ok in the northern winter.
If you have computers/clocks/inverter, you would have a parasitic drain, so depending on battery conditions!!!!
.... Philip
