Need help with brake chambers
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gkmissingca, Jul 16, 2017.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    To start, my background is in cars so I'm still learning air brakes.
    I'm converting a truck to single axle and the donor axle only has service brakes...oops. The travel at the clevis pin is only about 1.5" and the rod at rest only has about 1.75" sticking out. Most parking brake chambers I see have really long rods and aren't threaded far enough down. Could I buy this : www.oreillyauto.com/detail/brakebest-hd-2911/agriculture-hd-parts---accessories-19818/fleet---heavy-duty-20088/air-brake-compressor-valves---products-20110/hd-truck-brake-chambers---accessories-20251/piggyback-kit/bps3030/2543576
    And make the service brake a parking brake? The old service brake is an MGM 30 67-1.
    Thanks in advance.
  3. AModelCat
    156,931
    That isn't the pushrod in the picture of the park chamber you posted. That is a caging bolt that compresses the big park spring. That is only the park half of the chamber and gets installed in place of the back half of the service chambers you already have on the axle.
  4. gkmissingca
    102
    29
    Feb 18, 2017
    Ok, I understand that's the caging bolt. So in theory, I should be able to take apart my service brake and add this piggy back?
    Edit: oh duh, that's what you just said.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,132
    Mar 5, 2016
    White County, Arkansas
    Caging bolt, aka maxi bolt is designed specifically to DISABLE the parking portion (The spring) when installed. It compresses your spring on that side of the brakes so you cannot have it locked down and roll during towing etc.
    There is nothing there for you with that bolt. It is made for that exact purpose and wont help you at all.
    What I think you are about needing to do is to find a complete assembly that has both the service brake side and a parking brake side for that axle. I don't know enough about axles but think they should make replacement brake assemblies for specific axles.
    I don't know if I want that donor axle that only has service braking on it. You need a axle with a complete braking, both parking and service already on it.
  6. AModelCat
    156,931
    The complete chambers (service and park) are cheap. Just bought 2 Bendix MGM style 3030 chambers for $60 each plus $30 for 2 clevis kits. Just gotta cut the pushrod to the correct length as per mfg. instructions.
  7. gkmissingca
    102
    29
    Feb 18, 2017
    Ok thanks. I just wasn't sure on cross compatability on these chambers. I took apart my old service chambers and diaphragms were heavily cracked too so into the junk pile. Did get the clevis off though. Thanks for your help
  8. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Just put 2 new piggy backs on where the service pots are currently installed, cut the rods to length and plumb the new pots off of your original triple valve the same way they were plumbed as a tandem.
    Service pots actuate when air pressure is applied, spring brake/maxi brake pots actuate when air pressure is cut off; they are different beasts entirely.
  9. gkmissingca
    102
    29
    Feb 18, 2017
    I ended up finding two brake chambers on ebay. The main problem I had was finding the rod with enough threads cut down close enough to the chamber. The bracket and lever are very close to one another. Most of the inexpensive ones I found had a couple of inches of uncut rod which would be too long for my application.....I think.
  10. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Hey Northern Mechanic....Do You buy chambers with OUR Flag on them??
  11. Professional Passenger
    Professional Passenger Bobtail Member
    48
    211
    Jun 2, 2017
    Dad's truck
    Diaphragms never go into the junk pile. They're free tools...
    They make great bolt/part trays when working on stuff.
    I think I have 40 or so of them. And the best part, unlike those pesky fancy magnetic ones, they're easier to clean after the job is done...
    stayinback Thanks this.
