Need help with cdl restriction
Discussion in 'Questions From New Drivers' started by bayoubob, Sep 4, 2016.
  1. bayoubob
    bayoubob Bobtail Member
    Jul 20, 2013
    I have carried a cld-a for close to 20 years and have been driving locally for that time,I recently went to a new job of passenger transport,I took my road test in a company vehicle which had an automatic transmission,upon getting my license I received a E restriction which limits me to auto-trans.My question is how can I have been driving a manual trans for 20 years and now I am no longer able to due to the restriction.Was just curious if anyone else has ran into this problem.
  3. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    Per the FMCSA, if you test on an automatic equipped vehicle, you get an restriction on your license that prohibits you from driving a truck with a manual transmission.
    (c) Manual transmission. (1) If an applicant performs the skills test in a vehicle equipped with an automatic transmission, the State must indicate on the CDL, if issued, that the person is restricted from operating a CMV equipped with a manual transmission.(2) For the purposes of the skills test and the restriction, an automatic transmission includes any transmission other than a manual transmission as defined in 383.5.
    crb and x1Heavy Thank this.
  4. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    looks like (to me) if you want your manual back, you'll have to re-test again, in such a truck equipped with one? then go about your business driving the automatics?
  5. racemaxx24
    racemaxx24 Heavy Load Member
    717
    919
    Jul 4, 2014
    East TN
    Sounds like he already had his full Class A, had to do a skills test to get his passenger endorsement and now they slapped him with an automatic restriction because the bus he tested on was an automatic (who has manual busses in 2016...). I would certainly be getting some clarification from the DMV if this is the case, I don't understand how they could add a restriction if you already held an unrestricted class A and were only testing to add the endorsement.
    Bean Jr. Thanks this.
  6. David_Simpson
    650
    637
    Feb 23, 2016
    that's right. on the back of my CDL it clearly states , restrictions and endorsements, maybe he misread his?
    crb Thanks this.
  7. Toomanybikes
    Toomanybikes Road Train Member
    2,360
    3,120
    Apr 8, 2009
    So how do you add a passenger endorsement with out the restriction? Their are almost no passenger vehicals without an automatic.
    Sounds like like somebody in the DOL office is inserting their own interpretations of the rules. It is an endorsement, to the commercial license, not a complete new license.
  8. bayoubob
    Jul 20, 2013
    Thanks for the replies guys,just to clear up I've drove 18 wheelers for about 20 years with manual trans,took the road test and was certified,now this new restriction makes that null and void,why should I have to retest in manual when I've already done that at one point and time.As per my license it clearly states on restrictions no manual trans cmv.Anyway guess I need to call the main dmv for my state and get clarification on this.As a side note I called the licensed state tester and he stated the restriction should not have been place on there since I was already a class-a cdl holder.Once again thanks for your replies.
    speedyk, crb and baha Thank this.
  9. RDBG
    RDBG Medium Load Member
    309
    692
    Jun 23, 2016
    I'm confused why he even had to road test at all. My licence covers passenger buses and semis because when I did all my written tests I had them throw that in since it was free. Here they have A for semis B for school buses C for other passenger buses D for straight trucks and so on. I have my AC with air brakes. If hypothetically I wanted to go drive school buses I would only need to do a written test to add the B since I road tested with a tractor trailer and already have my A.
    OP where are you located??
    x1Heavy Thanks this.
  10. David_Simpson
    650
    637
    Feb 23, 2016
    right, it should have clearly been a P endorsement, not a restriction.
    hopefully the deranged minds at the DMV will clear this up.
    crb Thanks this.
  11. MidWest_MacDaddy
    11,094
    18,558
    Feb 21, 2015
    South Carolina
    Ya, sounds like a simple snafu... Normally someone testing in auto might get that restriction so that's what they did... Without thinking you didn't have that restriction in place for 20 years.
    Talk to people higher up the chain of command and I bet you can get it cleared up. Front line clerk just doing their job. Happened to be wrong in your case.
