Need help with my Cobra 29 NW St
Discussion in 'CB Radio Forum' started by bulldozerbert, Oct 15, 2009.
  1. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    I do not know much about CB's and what all the knobs and buttons do.
    what position should I have these in?
    S/RF NB/ANG Tone
    SWR ANL HI
    Cal OFF NOR
    And also, in easy terms, what and where do I roughly need the dynamike, rf gain, and SWR Cal?
    Thanks for any info you might share.
    I probably should stop at a cb shop, as the antenna's were on the truck, and may not be matched.
  3. Rat
    Rat Road Train Member
    SRF-SWR-Cal in the S/RF position
    NB/ANL-ANL-Off Either in the ANL or off posotion depending on amount of noise
    Tone Depends on how you like. It just slightly changes the incoming voice.
    RF gain all the way to the right
    Dynamic Depends on the mic being used. I use an astatic 636 L noise canceling mic and leave mine fully to the right. I tell soft spoken talkers to turn it all the way up but louder talkers to turn it down slightly.
    The swr cal is just for checking the antennas. Switch the S/RF-SWR-Cal to the cal position. Turn to channel 20, Key up mic and turn the SWR Cal knob till the needle on the meter swings to the little square in the top right corner of the meter. Then switch the S/RF-SWR-Cal to the SWR position and key up the mic again. Note were the needle is. If it goes past the 2 in the meter then you need to get your antennas or coax checked.
    That is about it in a nutshell. Oh leave the sound tracker off unless you are running with someone else that also has it.
  4. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    thanks, that is what I was looking for
