Need Help With Self Certifying
Discussion in 'Questions From New Drivers' started by Johnnymic7, May 4, 2017.
  1. Johnnymic7
    Johnnymic7 Bobtail Member
    12
    May 4, 2017
    Long Island, New York
    I am going for my New York State A Class CDL Permit. I think I should certify as Expected Interstate which doesn't require Medical Clearance. Here's my reason why, please correct me if I am wrong.
    I am taking an unpaid internship for a private entertainment company. The rig is used to transport private equipment owned by the small business owner. The rig is owned by the small business owner. The truck will not be for hire. It is used to transport private equipment and private passengers...the owner...his kids etc. We are not using the truck to pickup and transport any people or other people's property for money at any point. We are not looking for hire. We are our own business.
    The owner wants me to drive the tractor in parking lots on tour throughout the USA with him on board so I can learn. When the tour is over I will return to my home state and take the test.
    Am I correctly certifying myself?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Using Arkansas, you are swearing to sign under Tier Two.
    Tier two is excepted trucking. But for me the way the revenuer (yes we still use that word) told me is that Tier two is for purpose of hauling dead bodies in time of national emergency for example.
    Using Arkansas's Affaidavits you will be likely excepted trucking, but section line J under Tier two might or might not be a barrier to you.
    http://www.dfa.arkansas.gov/offices/driverServices/Documents/selfCertficationRE.pdf
    Type 2 –
    (EI)
    Excepted interstate –
    No Federal Medical Card is required.
    Engaged in interstate commerce and ope
    rating under one of the following
    exceptions:
    a.
    All School bus operations;
    b.
    Transportation performed by any political subdivision;
    c.
    Transportation of human corpses
    or sick and injured persons;
    d.
    Operation of fire trucks
    and rescue vehicles while i
    nvolved in emergency
    and related operations;
    e.
    Operation of vehicles designed or
    used to transport between 9 & 15
    passengers not for direct compensation;
    f.
    Transportation of propane winter he
    ating fuel or responding to a pipeline
    emergency;
    g.
    Farm custom operation: custom-harve
    sting operations,
    transporting farm
    machinery, supplies, or both, to or from a farm for custom-harvesting
    operations on a farm; or transport cu
    stom harvested crops to storage or
    market;
    h.
    Operation of a commercial motor
    vehicle controlled and operated by a
    beekeeper engaged in the seas
    onal transportation of bees;
    i.
    Operation of private motor carr
    ier of passengers (non-business);
    j.
    Occasional transportation of persona
    l property not for compensation or
    commercial enterprise;
    You cannot claim type 4 which will clear you completely for the work you describe because you travel the USA. Type 4 is strictly inside the state only. And only inside.
    Johnnymic7 Thanks this.
  4. Johnnymic7
    12
    May 4, 2017
    Letter i. Is where I think I fit the bill...but I'm not sure. The guy at DMV didn't even know.
  5. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Vans up to 15 souls can be run without a CDL. If you are carrying more than 15 souls and getting towards the really big three axle motor coaches with 50 souls.. yea you need a CDL and P endorse ment. etc.
  6. Johnnymic7
    12
    May 4, 2017
    Only 4 passengers and a 18 wheeler full of private equipment. Such a grey area it seems
  7. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Ok, you are talking two vehicles then?
    Unless you class 6 or class 7 tractor with crew cab to carry 4 souls and a trailer on a 5th wheel at something not reaching 80K gross.
  8. Johnnymic7
    12
    May 4, 2017
    4 passengers with a cab and a typical big long trailer with private equipment. Again I'm an unpaid intern and everything on board belongs to the owner.
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    https://dmv.ny.gov/commercial-drivers/cdl-medical-certification-requirements
    Question is.. under Excepted InterState do you meet the requirements?
    https://dmv.ny.gov/commercial-drivers/a3-restriction
    I would say you still fall under Non-Excepted Interstate and require a Med Card.
    Non-Excepted Interstate (NI)
    Commercial driving operation is permitted across state lines, and you are required to meet the Federal medical requirements.
    Excepted Interstate (EI)
    Commercial driving operation is permitted across state lines for excepted operation only and you are exempt from the Federal medical requirements.
    • you must be age 18 or older (21 or older when noted for certain excepted operations)
    • you must have an A3 (Med Cert Exempt) restriction on your driver license
    • you must not have a K (CDL Intrastate Only) restriction on your driver license
    A3 Restriction
    The description of the A3 restriction will change from "Municipal or School Operation Only" to "Med Cert Exempt." This encompasses all of the federal and state Excepted types of operation.
    If you operate only in Excepted Interstate or Excepted Intrastate operations, you are not required to hold a USDOT Medical Examiner's Certificate. If you are Municipal or School operator, you will still be eligible for the A3 restriction because these are Excepted types of operation.
    If you currently have an A3 restriction, you do not need to amend your license to change the description of the restriction. The "Municipal or School Operation Only" description is valid until you renew your license. When you renew, the restriction description will automatically be converted to "Med Cert Exempt."
    brian991219 and Johnnymic7 Thank this.
  10. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    [QUOTE="Mark Kling, post: 6084064, member: 10713"
    The SUPER big question is are you allowed to leave the State with only a Permit? https://dmv.ny.gov/get-cdl
    tscottme and Johnnymic7 Thank this.
  11. Johnnymic7
    12
    May 4, 2017
    So let's say for now, I only drive the tractor part in a parking lot to get used to it for a few months. Expected Interstate would work?
